mk1 16v KR not firing up
grry said
Where do I find/buy a k-jet pressure gauge mate ??
I have one. Whereabouts are you? Do you want to bring it round and I can take a look at the fuelling or buy the gauge off me?
How much do you want for it ??
grry said
Im in Newcastle mate and the mk1 isnt runnung so wont be able to bring it to you
PM sent
The fuses and relay are ok so why would this happen
hope u get ur problems sorted soon.
boomboomeroo said
dunno if you messed with the accumulator at all but if you have the pipes on the wrong way the pump will start to struggle( i did ). also i would connect your pipes to the ecu all that you need is a T peice you will get the pipe no problem. Your fuel pipe has to be 8mm i am pretty sure. Thats what i have on mines and no problems so far.i know you have alreayd said you have the plugs on the right order but just to be certain
1—2
–0–
3—4
from looking at the dizzy straight on
and obviously the order from the cam side 1 2 3 4
Is this plug order correct for my 83 gti too?
boomboomeroo said
there is a connecter up by the ecu wiring 2 pin check that. also there is a single wire (live) that comes from the fuse box. It is the centre black plug. Check that The pin for the wire is E14 if i remember correctly its marked on the fuse box.
The 2 pin connector you mention, is it a black connector, with a black wire and a yellow/red stripe wire?
I currently don't have this connected up, as the other part of the loom this was connected to I have not used.
But now I have no power to the pumps, wur etc, and no noise from the relay, so im guessing this should be connected up?
Sorry to hi jack the tread :wink:
Pete.
the red/yel wire is the fuel pump trigger earth, it is only required if you use a 16v/digifant type fuel relay. If you have a k-jet 8v relay you dont need it
But still not getting fule to the injectors uch:
:y:
Can any body help please
Also what connects to this part on the bottom of the black casing?
well, the top blue hose is the fuel return from he engine, the black hose next to it is the feed to the engine. the other nipple on the top is the return to the fuel tank and the last connection on the bottom of the plastic reservoir is the feed from the mk2 lift pump
Hopefully it will fire up then I know I need a pump
When I rig up the mk2 16v pump the mk1 lift pump cant seem to supply enough fuel from the tank but is seems to be fine when I connect the mk1 GTi pump
Will the lift pump need changing for a better item ??
Any help people
Could this be the problem as its not wired up ??
