Where can i get a lightened flywheel for Mk1 Golf Cabriolet?
fthaimike said
I just started worrying what others would think when you mentioned my pictures, what work was done & the wording "dangerous" in the same paragraph as people may have thought you meant mine…
sorry for any confusion either way.
No need to be sorry. I would consider myself as being irresponsible if I didn't at least note that there are bad sides to something. The mis-understanding has lead to some good and maybe helpful information being passed along so no harm done.
lightened flywheels
Hi guys, helped me no end, i now have all the info and picturs i could have dreamt of when i posted. Now then, any pics or info on crankshafts and connecting rod lightening and balancing???? :dontknow:
It's ten years since i went out of my my mind - I'd never go back.
Mk1 1993 Cabriolet
Audi A4 SE Avant
Audi TT Roadster 225 Quatro
Mk1 1993 Cabriolet
Audi A4 SE Avant
My 2.1 8v will be set again to a limit of 6300 which was plenty for it & will have the lightened/balanced hotgolf flywheel fitted but no other internals heavily worked on as it did fine hitting the limiter in every gear every use for 124,000 miles without a hiccup, only when it overfuelled was any damage done though not related (cracked a piston with heat) so it was fully rebuilt but was a testament to how strong she was.
Re: lightened flywheels
Melly said
… Now then, any pics or info on crankshafts and connecting rod lightening and balancing????
You are venturing into a different area then just installing a lightened flywheel. You first have to ask yourself if you need or want to spend the cash to do it? The cost is not all that bad, but if you don't plan to spin the engine all that high then why waste the money. Yeah, it would be a smoother engine, but VW does a fair job of factory balancing anyway (better then many other companies). Then there is your question, crankshaft and connecting rods? That would be a waste as the entire rotating and resipricating mass has to be ballanced to be worth doing. That means shipping or sending the entire ball of wax, Crankshaft, rods, pistons, pins, clutch assembly, even the rings really. And I have seen two versions of balancing done; a) weigh everything, match the weight to the smallest, crankshaft in a kind of "V" block to spin it and see where is settles and adjust the weight according (cheap method) b) all pistons/rods/pins/rings matched then a bob weight attached to the cranshaft with clutch assembly installed and spun, the computer on the machine tells exactly how and where to adjust the weight (more expensive but the best).
flywheel lightening
Cheers Simon.
Mk1 1993 Cabriolet
Audi A4 SE Avant
Mk1 1993 Cabriolet
Audi A4 SE Avant
most will just stick a 16v in & there you go but they didn't come with one so that would break your competing rules.
all i can say is that my 2.1 8v was about 165bhp 154 torque but it cost a lot of money as i had to pay for the work to be done.
It had a larger pack C head, gas flowed & ported, diesel crank, larger pistons, audi80 throttle body with ground out inlet manifold, 1.6 metering head (more fuel), baffled sump, kstar II engine management etc……
Cheers Simon
Mk1 1993 Cabriolet
Audi A4 SE Avant
Mk1 1993 Cabriolet
Audi A4 SE Avant
Cheers Simon.
Mk1 1993 Cabriolet
Audi A4 SE Avant
Mk1 1993 Cabriolet
Audi A4 SE Avant
16 would do it easier mind
maybe on a crazy cammed revving itb motor it could be a lot higher but again cost.
a standard engine was 112bhp iirc so not a bad jump & the torque was lush.
I have a 4+E box with a quaife atb diff that suited the power curve well.
Cheers Simon.
PS what are itb's are they something to do with throttle bodies and what do they do?
Mk1 1993 Cabriolet
Audi A4 SE Avant
Mk1 1993 Cabriolet
Audi A4 SE Avant
The quaife was the biggest & best mod i ever had, you set it into the corner & plant it. Though it is either on or off so backing off mid corner can make the car tail happy.
You could alway dream of having an engine like this in your mk1:
http://www.youtube.com/watch?v=n8i5G4l6Kkw
8)
Mk1 1993 Cabriolet
Audi A4 SE Avant
Mk1 1993 Cabriolet
Audi A4 SE Avant
Cheers Simon.
Mk1 1993 Cabriolet
Audi A4 SE Avant
Mk1 1993 Cabriolet
Audi A4 SE Avant
4+E box would be no good for you, it was just available at the time and was better suited to my torquey engine.
Longer gears (4th goes to about 115+) & the 5th gear (the E gear) is just an economy gear for motorway driving so it drops the revs right down, maybe a diesel gearing?
A lower ratio box would be faster.
Mine when it was used on track just to show you it revving etc & to compare the speedo even on a small circuit:
http://video.google.co…ei=ahdmSsyTC8zN-Aaoi81c&q
Get some good top end & heavy braking with the big front brakes (check out how quick the speedo drops sometimes).
has the odd mistake on the same corner were i concentrate to much on the car infront & loose my line.
http://video.google.co…5155880962033013290&hl=en
fthaimike said
no idea myself sorry
sacked
at a guess i think its alot :mrgreen: you elt the weight of one of those 02a puppys
lucky for me i run a 020 with my 20vt which means i run a lighter flywheel lol
Many thanks
Shepp
