Instrument Cluster
(In Topic #113704)
Instrument Cluster
But the diffrence between this one and the one i got is that in the top right hand side mine has a sort of swtich which you can turn left or right which has a number 1 and 2 above to correspond with the switching, what would this be for?
Also am i correct in thinking that this cluster has come from a cabriloet? if so what year would that be??
Thanks in advance guys!!!! 8)
Life Member
You may have a problem fitting it.
Dan
Thanks for the replys guys I will try and get up an image later on if that helps 8)
Thanks,
Jeevs 8)
if you want the mfa bits to work you'll need to get the stalk plus all the wiring, fit sensors to the engine and run the wiring thru the bulkhead etc.
Just want to know where its come from
Cheers once again
Cheers once again
Thanks for all the help once again 8)
Dom123 said
is there a diff between 1.6 and 1.8 clocks?
There's different 1.6 clocks and different 1.8 clocks! Most 1.8s have MFA, there's at least 3 different variations of clock for these, however I guess there's a few 1.8 GTIs without MFA. If so then the clocks will be the same as the series 2 1.6 GTI.
Don't think any 1.6s will be MFA as standard and all 1.8 injected engines in UK spec will have MFA. Cabrios may vary slightly but would think they'd be the same?
Imports and mucked about ones may be confusing matters
Cheers once again John!!!! 8)
Cheers John
