Lukes Lhasa Green '83 GX
Just square pieces of vinyl?
yep its fablon bought from B&Q for only ?5 a sheet.
\'83 Lhasa Green GX 1457cc
\'53 Mk4 Golf R32, Deep Pearl Blue
\'00 Kawasaki Ninja J1 ZX6R
\'92 B3 Passat Estate 1.6td (Now breaking) 😭
The front panel with a couple coats of black stone chip paint
Stripped all the dash out to sort a couple problems (didn't need to take it all out in the end, although there was loads of leaves and broken glass under the dash  :dontknow: ). Got the heaters working, needed a new fan switch and fuse had also blown. Horns wasn't working, fitted relay and removed bridged piece of copper. While i had the dash out i routed in some new speaker wire for the door pods as a previous owner took it all out
Here is a couple pics of a stripped dash if you haven't seen one like this before
Also you will notice from some of the pics that in the past the wiring has been chopped about before. This wiring mess hangs near where the cigar lighter should and i have no other wires for the cigar lighter so guessing this is it. Would somebody be kind enough to send me a pic of how the wiring should be.
