My Mk1 Golf Project..about time i showed you all!
something fruity eh? you got plans?
1272 driver with a magic tree!!
Looking forward to show season now!!
Mines still in the garage, got another mk2 i'm working on.
Are you on swdubs?
cant get the exhaust to seal properly either which is a pain but I'l crack it..I dont think im on that site i'l have to have a nosey at it.
So your on a mk2 at the mo are you? I take it the golfs just been mothballed for now?
A few small points if anyones going the same route.
1 The ashley conversion manifold is a bit poor in my opinion, its tough enough but really quite ill conceived, the lack of a swoop for the anti-roll bar is a glaring oversight and the Downpipe is a monkey to seal. Although I will admit to this being more a down pipe problem than the manifold itself.. But still for the cost its still not what I expect. Save the extra fifty quid and get the supersprint one or stealths..miles better from what I can see.
2 If your using bike carbs position your mounting clips very carefully..The thread body on the clip can stop the carbs sitting fully home, resulting in them popping off as I experienced one day. Always double check this after any work on your carbs eg rolling roads, and head rebuilds etc.
3. Use proper fan mounts if you fit a slimline fan, ebay plastic ones are awful and become brittle in days.
Other than that everything else is great. The carbs are Fantastic, Producing a wonderful note on throttle and very responsive too. The H & H ignition system is a thing of wonder!! It hasnt missed a beat and Id recommend them thoroughly !!
So there we go, You can make a old skooler reliable and a different daily drive to the norm…we love em!!
H and H
Just wanted a bit of info with the wiring side as i am useless with wires. Does this H & H system replace the ECU and does that mean that wiring is down to a minimum of wiring in temp and pressure senders etc. The main point of course is the cost of it!!
Any advice gratefully recieved
Yep the H and H system gets rid of all ecu, vacuum advance, the lot. Just two wires to the supllied coil.
THen its just a case of hooking up your temp wires etc.
Give em a ring mate because its been almost two years since i bought it. It was around £250 though.
Good luck with the project bud, you wont be sorry you did it!
http://unitwan.co.nr/vw.htm
