1990,1.8,karmann clipper/alpine white
Spudfingers said
8O 8O …. errrrrr… what do I think…. I think you'll be doing mine next !!! Well done mate she scrubs up a treat!!
finally finished the front arches today, took a while tho cause every half hr had to run for sheltor as it would poor down , start! stop! start! stop! got it done tho and looks nice well pleased, if you want your doin spud i can come and help u it would be alot quicker job with 2 :wink:
GOLF MKII GTI 8V - sold
GOLF MKII DRIVER - ex took it
GOLF MKII GTI 16V - scrapped
JETTA MkII GTI 8V LMT EDTION
your prob right its prob some car being burnt out by local car thieves ha ha.
that was last night, it was mad that was at my mates just up the rd when i got home the sky had actually turned pink and lavinder colour but couldnt get a pic of that one with the car in it cause the trees were too high
zambeaky said
thinking about coil overs for my cabby, can you get them at a standard ride hight and can you get them so they are not to hard maybe a little firmer on the rear but i dont want to fit bone shakers on the car?
Nope, coilovers basically lower your car loads and make the ride hard! That's what they do!!!
the good thing tho is as winters not too far away now really i may as well wait now til next summer for wheels, that gives me all winter to save and decide wot to get, i really like those two sets i showed you tho if the money does come available buy some miracle over the next couple of months and their still available i shall get them :wink:
before i go removing things i dont need to remove taking a look at things am i right in thinking that the high beam lamps (which i wont be removing or changing yet) can be removed and changed with out removing the grill but to change the main beam head lamps i will need to remove the whole grill?
the reason i ask is i'v noticed there's a series of plastic clips holding the grill in place aswell as bolts so before i go trying to pop the plastic clips out that could be brittle with age by now i thought i would check that it is necessery to remove the clips and grill …… :dontknow:
so over all had a constructive day today, just need to pop to the garage tomoro and get them to line my lights up so their aiming correctly
whilst i was under the bonnet i checked my oil levels… all fine… checked in the oil cap and fine…. checked my header tank for the water and was nearly down to the bottom of the header tank, i topped it up went out the next day all was fine idle speed still slow and lumpy so when i got home checked header tank and had lost about half a header tank of water again so topped it back up but also noticed a hissing noise from the header tank cap caps on as tight as can be so thought maybe just the seal was worn on the cap so im loosing steam through it.
well today i checked water level all fine and checked inside the oil cap and noticed this on the cap
on this pic dont mistake the the wear on the rocker cover filler nick as creamy coloured oil its just warn off paint down to bear metal the rocker cover seems to be ok inside the dicoloured oil seems to be only visible on the inside of the cap but with the black plastic cover over the top of the cam inside the rocker cover you can actually get a good look inside to see whats really going on
is this to worry about, are these the signs that my head gasket is going, i was guna try and adjust the idle speed but now im not so sure to do that as if there is another reason the idle speed is playing up then i could be just compensating for a problem by adjusting it and carry on driving when infact there were warning signes there and i'v just covered them up and causing further damage
when i changed the plugs the colour idication on them suggest that my engine is running normal, not running weak or rich and that the engine is in good condition?
when you look inside the rocker cover you cant actualy see any discolour to oil it only appears to be on the cap its self and the rocker cover filler neck, i'v checked the oil on the dip stick thats fine
any idea's, i will have to take it to the garage i think monday and get their opinoin but was wondering if any one on here thinks this is something to worry about ie the head gasket??
