Mk1 Golf 1.1 C - TDI Conversion
scott
i have a massive dent in the drivers side sill at the front near the wing, it was so bad the sill was rubbing on the door when you closed it….. The paint had cracked and it had to surface rust, Oh and where the jack had cause the middle of the dent it had pierced it….
So i have no before pics , but the process was….
Drill a couple of small holes in the inner sill so i could get access with a rod to the inside of the dent, and "fettled" ie. Smashed the dent out as goof as poss, this left a bit of metal beyond repair so a small patch (3in x 2in) was cut out, and a replacement section was butt welded in.
All ground back with a flap wheel
Then filler was applied, sanded back with 40 grit, then 80, then 120.
Then a skim of putty, sanded with 240
Etch primed any bare metal
Primed the lot (upto the remaining paint)
Applied 3m stone chip (Awesome stuff and really thick)
Painted with 4 coats of mars red…
Im really happy with the result, i was nervous about this to be honest as it was so badly damaged to begine with , but it turned out well….
Oh yea, Inside the sill it was coated with waxoyl to prevent water penetration from inside the repair….
heres the pics…
Just trying on some bbs ra's……….
Haha.
any idea where i can get these from?
also note the blue bonnet, i have stripped the red one to metal and its gonna be painted next weekend hopefully, im not sure if i have enough paint left though….
Also, can you spot the interior? Its not finished yet so dont was to put up proper pics..
Scott
car looks great!!
i was wondering what seats you have used? Someone fitted GTI seats in my Golf C but i wanted something different to that and the pattern on yours looks good.
1, 2, 3, 4, 5, 6???
:twisted:
the best bit of any project, the ENGINE :mrgreen:
So i made a trip up to york this weekend in horrific weather, ended up gragging a guy off the A1 M in his focus (he flipped it at 70 mph) he had landed sideways in the slow lane, so 4 of us tried to push it off and it was hard work as the rear wheels were shot!
Anyway.
I had to put this shot in…..
And inside………………….
TaDaaaaa!
A '98 AHU TDI 90Bhp….
With FSH and running perfectly… mmmmm
And here i am driving the other half mad with a full vento wiring loom on the floor in the living room!
and a picture of a strange acorn on the exhaust manifold…..
Oh no, its just a very small turbo haha!!!
I have ordered some engine mounts from the caddy forum, as i cant spend a month making mounts, and i know they will fit perfect….
Cant wait to be getting 60mpg !!!
Cheers, Scott
will have loads of updates at the weekend. As im stripping the engine a bit of the uneeded crap. And cleaning it up.
The hopefully doing…
cambelt and tensioner
Waterpump
Rocker cover gasket
Clutch
Fit seat clutch push rod mechanism to convert hydraulic to cable clutch
get my mounts on the gearbox (02A) (From vw caddy.com), fit mount bushes,
Decide whether to change the sump gasket.
I should have the intercooler done by tomorrow night.
So lots and lots to do! Need the engine and everything ready to slot in by xmas. As i will be fitting it over xmas!
Scott
Love it lol 8)
that wouls be…. different
Ah i havent pictured my fresh painted bonnet yet!
i'll do that at the weekend too! Did it myself in the garage, it came out pretty well, considering how cold it was!!
lol
you want it ? haha.
allan , ive honestly considered every possible engine,
16VT, 20VT, G60, VR6 blah blah, PD TDI,
This has the best of all worlds, and relatively cheap even doing it properly.
Spent 300 pound at GSF and VW today on just service bits,
cambelt, waterpump, sump seal, rocker seal, oil, filters, coolant, all of the engine mount rubbers, mechanical clutch conversion from VW (seat unit) and some other stuff
money money money
cheeers, Scott
as it was a 1.1c before, does the mount on the chassis leg have to be moved and flipped over???
It looks too far forward. If it does, this is a set back
