Mk 1 Golf Clipper Running Problems
To help you to twist round need to find something the right size that can bridge two of the gaps together to help you get some purchase. Try an expansion bar from your socket set.
1988 1.8 carb Golf Clipper
What was the outcome…..read all the way through…but does not say what the final outcome was???
Would be good to know.
Thanks :wink:
still cant get the top off the tank..but having replaced the inline fuel filter there is still rust coming through so really need to get the cap off and have a look… hopefully it is just old rust that is till in the tank as the filler neck has been replaced and the tank cleaned.
will post an update once iv got the cap off and looked at the sock/sender..
cheers and thanks all for the help!!
After replacing the in-line filter the car seems to run better however we are replacing the tank and going to blow back the fuel lines and replace the in-line filter once fitted.
Will update once this is done.
The in-line filter we took off and replaced was full of rust!!
Have some good pictures but cannot upload, unless someone can do this for us?? I have the pictures available to email if someone can help??
darren.frame@hp.com
Rust in Fuel filter
Tank Cap
Rust in bottom of fuel tank
I can't remember if the bottom of my tank looked like that…..if it did i think i would have remembered it….
Best of luck…I'm changing loads of stuff on mine today!
Also had a thread running on here for many months with lots of advice but did not solve the problem until an auto electrician became convinced it was fuel related. Sods law it was the last thing replaced and was the cheapest !
So, … if all else fails !!
Black Cabby
any fuel left in the tank i would pour into a container and keep for cleaning purposes, wouldnt be going anywhere near the new tank!
Have you found out why there is debris in the bottom of the tank. (edit just read filler neck replaced). You still need to find out how that debris got there.
Anyway we drained the tank of fuel using an electrical fuel pump and a 20 litre fuel can. All filtered of course. Then we took the sender unit off. The previous owner had made a real hash of taking this off previously with large chunks of it missing and sealed over with some silicone.
Anyway after leaving it to vent over night we got the hoover in the tank and sucked all the crap out of the tank. If anyone else does this just make sure you have a fire extinguisher to hand as i wouldn't advise doing this really but it did the job quite well.
Anyway replaced the in line fuel filter and did the filter inside the carb. How many people have replaced/cleaned that one??? Its located, on a weber carb, just below the fuel intake, with a 19mm plug. If you haven't chack it out
mini old skool of course - 1310, lightened and balanced bottom end, fast road cam, MG head, Megajolt + EDIS, stripped out interior
Metro Autograsser - built myself
