Webber carb
Webber carb
The car won't idle now, so i had to increase the idle speed screw a little but there is something at the front of the carb on the adapter plate with a wire and that came off when i was screwing it to the flange, it is connected but not sure if its working as it should, any ideas pls? :roll:
Danno387
:roll:
if not then the its blocked or the pump diaphram is knakerd
if first you dont succeed. read the instructions.
I've joined you on this mission on my own car!! Are the fuel vapour thingys on the front available anywhere or the same as this?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300268310157&fromMakeTrack=true&ssPageName=VIP:watchlink:middle:uk
Asking as mine is rusted to heck! But me inline filter is clean and the fuel pumps thru there nicely but will be checking timing, plugs, leads tomorro, wanna change that vapour thingy n am going to start again re-setting the carb after that!
Found this on here to help with setting up the idle if it helps?
CARBURETOR SET UP AND LEAN BEST IDLE ADJUSTMENT
Hopefully we'll both get sortd eventually even if i have only had my car a whole 8 days!!!
