Webber carb
(In Topic #109183)
Webber carb
I have taken some pics of the engina bay and carb but no idea how to upload them?
Pete :wink:
Webber carb pics
For some reason i can not see your Vacuum pipe that should go from back of carb and join on a y-piece adaptor, one going to the left of carb and one to right to servo pipe?
Reason i mention this is even thou you have the air filter box off that pipe on the right should be visable.
I can see vac pipe from the left side of carb.
Have you checked fuel sender underneath rear bench for rust blocking the small filter, have you replaced filler neck if it already hasn't been checked or replaced, i see you have fitted new fuel pump, why not fuel vapour separator above it?
Also i don't like the look of the fuel pipe going to the carb, looks like vac hosing?
Change your rocker cover gasket also, and reposition the ht leads over the fuel pipeand water pipe as how you have it now you are putting stress on them as they have to bend around numerous pipes thus can cause cracking in the leads, leave them at top so resting freely on other pipes.
Check the dizzy cap androtor arm to see if any damnage, and lastly as suggested by Novacaine, Timing, but i do think this is elating to the vac piping, but we'll get everything covered and get you sorted
Yes i am a fussy git but their is a reason for my madness
Pete :wink:
I took the cover of the carburettor and discovered lots of debris inside the carburetor bowl, it was this debris that was blocking the jets etc.
The debris comes from the fuel separator / return reservoir mounted just below the carb. There is no filter after this before it gets to the carb.
After a time it will rust internally and shed debris. I purchased a new one from GSF. I cleaned the carb, all the fuel lines out and replaced the filters. You can fit an additional in line filter between the separator and the carb for additional protection. It worked for me.
quote]
Thats just fibre rapped fuel hose pete. perfectly normal. i even have it on my car.
Peddersgolf said
Have you got a wider shot of carb and some of right side?
Pete :wink:
Hi Pete
thats indepth mate, and very thorough i will get some pics, better widershots and of the engine bay and carb.
there is a vacum pipe that leads from the brake servo but that is connected to the distributor but there seems to be another pin on the brake servo pipe that looks blocked with silicone as it think it broke off :dontknow:
Now the vacume pipe from the rear of the carb is connected to the left on the air filter :dontknow:
i will get a new fuel vapour separator and hope this sorts it, timing i will have to get a timing light and check.
Also what are your views on the air/fuel mixture screw, how many turns is adequate to adjust from closed position? I notice in the morning when i start the car it idles with a bad miss then clears off app a min after, not sure what that is, takes a while to heat up and run smooth, have to use the choke.
for all the advice
Suren
vac pipes need placing correctly fella
Follow this tut fella, in your case if one small pipe has snapped on the servo, Look at the last pic i posted in the link
Pete
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=57627
Cheers Pete
From cold start with choke for app 1 min the car idles as if it has a bad miss then clears out and now it seems to have developed a flat spot at the very top of acceleration.
Still feels like its sucking air from somewhere, i think i need to change the flange but can't seem to get one anywhere, any sugestions?
i am almost there
new flange.
might be worth redoing your timing now aswell
(I will be sorting my Vac pipes and fuel pipe issues this weekend)
Out of interest….what is the Carb Flange that we need? Can it be ordered from GSF? (I have the webber carb too)
Get from here as they are cheapest at moment, credit crunch and all gotto save every penny we can
before you say, they are same on the mk2 golf also :wink:
http://cgi.ebay.co.uk/VW-GOLF-MK2-CARBURETTOR-MOUNT-FLANGE-1-6-1-8_W0QQitemZ330315300765QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item330315300765&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
Its the rubber metal mounting at the base of the carb, if it is cracked or worn it will need replacing. I did what Pete said and connected my vac pipes correctly and what a difference to the idle and pulling I also feel there is some air being sucked threw the flange so i am replacing that too.shooterdee said
You have all my symptons and Vac pipe problems…..any update?
Reset my air fuel mixture and idle speed yesterday and even better now with cold start, the car is smooth, will give you update when i have replaced flange, there is a sticky that Pete wrote on vac pipes, brilliant thread, cheers mate
Pete :wink:
i've already ordered flange frm crazy quiff but not sure if it will ft though, as it says its for a pierburg 2e carb, emailed Richard, no reply yet, cheersPeddersgolf said
Glad your sorted, but like you say you think something is sucking air in, no point adjusting anything until carb flange is replaced then it will be 100% ok for you fella
Pete :wink:
Pete :wink:
