low 5dr GL 1.8 carb - NEW PICS - 23.09.09 - I IS Two-Tone
ash
after having my new rear valance welded on, i thought i'd better tidy up the rust behind the number plate.
wish i'd checked this out before as i could have done with a whole rear panel!
behind the plate wasn't too bad i guess,
it was where the rear panel joins the boot lock area and the number plate light cut outs, holy!!!
the plan is too fibreglass the holes around this little block so i keep the cut out for the number plate light.
after some fun with the grinder
as the rear lights were out i figured its a good time to repaint the black strip across the middle
i'm gonna finish off the filling this afternoon, when i get my lights working properly.
ash
Tom :wink:
1991 Diamond silver 1800 16v Corrado 'Betty'
Gone, but not forgotten;
1985 Lemon yellow Polo coupe S
1983 Gambia red Golf C
1983 Diamond silver Golf GX
1981 Mars red Golf GTI
I neeed to get mine lowered too!
Cheers.
jetpac - you have a pm.
i'm getting there, slowly. lovin this sunshine though.
some filler work on the rear panel
abit more fibreglass around my template block for the number plate lights
block removed
after some grinder/dremel work
some fine filling needed, but its definately taking shape.
as my mk1 is my daily i wanted to get some paint on. so its just black for now.
just need some new screws for my new number plate lights and i'll be night time road legal again.
jetpacjimmy said
loving the look of this mate, good work. You've inspired me to do a few mods of my own, I'm definitely going to get the front bumper with the washers now, one question, is there an internal switch for these or does it run off the stalks? If it's a switch would you mind posting a pic of what it looks like if you get a chance?
Cheers.
sorry to hijack ash..
our GL has th eheadligth washers and the still work.. they only work when te headlights are turned on andthen you use your screenwash..
have a spare bumper with a set still fitte dif you want them for the look drop me a pm..
As to wiring - no idea how to do it!!
ASH
sorry mate, couldt resisit!!
Gutte don finding the holes mate, shame you didnt see em before the welding.. wouldnt be suprised if thats where the water was getting in.. Nice work mate..
Keep up the good stuff mate..
Bugger! Just bought some off the bay, bit of an impulse purchase, but they weren't that pricey and in good nick. Will no doubt be looking for some more advice in the future when I get these on, although I'm not sure I need them to work! Thanks for the PM Ash and the advice Lawsy. Cheers, James
my ff sunroof has had some rust spots for ages that have become worryingly bigger. the seal looked tired too.
so i was gonna get a new seal (about ?40) and grind, fill and paint the sunroof.
Until… i read on here that mk2 sunroofs are the same.
sweet, a ?5 ebay purchase saw me more than happy and a local pickup too.
so on with the refit.
my tatty 27 year old sunroof
first job, unscrew the wind deflector. one screw either side and two on each of the two hinges at the front
pop off the head lining from the front and slide it back into the roof
unscrew the front guides, and remove
and the rear guides
prising out the leaf spring at the rear
slide out the locking tab
up, up and away!!!
doesn't look too bad from the top
…but underneath!!!
new for old
look how mint the seal is
the head lining was hanging on, so i got me fingers all messed up with some super glue.
a job worth doing tho.
new sunroof slotted in. rear leaf spring in place
locking tab slotted back in
screws back in front and rear guides, not fully tigt yet as adjustments will need to be made.
adjusting screw for the sit height at the front.
it sat abit low, so a little adjustment, tighten everything up and…
lovely.
i even like its shiney blackness.
i must add that i did follow the haynes book of lies and removed the winder handle and cable mech at the front, but i'm not sure why i did this!?!
so thats it.
i promise my mk1 is staying its original metallic regatta blue, even though its slowly turning black…
ash x
gonna keep it black or poss change to blue.?
it didn't leak before, i just wanted to cure the rust, and figured a new seal would be in order when i did this.
well, there was one time when i pulled in at a car wash fund raiser at chesterfield fire station. they let loose the water cannon straight down onto the roof whilst i was sat inside. after the initial shock i must have drunk a pint or two as the water rushed in. ha ha
it'll go back to blue eventually. i'm toying with the idea of buying a spray gun for my compressor and learning how to mix and spray paint, other wise i'll end up spending a small fortune on rattle cans…
ash
are you the bloke i saw in sheff centre not long ago near st marys gate?
also im a body repairer painter, so if you want anything painting
come to me and ill sort you cheap price if you get me the paint
yeah thats me.
thanks mate, thats good to know. i'll have to get to a lowdown meet or summat for a chat. i keep meaning to come down to one of the retro rides meets too, but not made it yet. :dontknow:
easy now
ash
didnt know you were on lowdown :s HAHAH
yer get to a meet
theres always out on either sooner or later
i'm maybe gonna lower it abit more , just wanna let the coilies settle back in abit and check for rubbing etc
ash
