Think i've got a 1.6gti but how can i be sure!!!
Web Team
a 1.8GTI head will fit on a 1.6 Block. maybe its been changed..
Only real way is as stated already. Etched in the block will be the code., under head, between plugs 3-4 ..flat area. Might be difficult to see..
also underneath, exhaust side will be a 1.8 or 1.6 cast into the block. Big letters!
then again bigger spanner in the works, 1.8L internals will fit a 1.6L block…
but as some my know my engine is out of the car and today i have started to strip it for a rebuild as the weather is to rubbish to sort the shell out
the engine number is EG
but then the number 1.8 are also on the engine
so it looks like there are some 1.8 EG engines
help me out here :dontknow: :scratch:
The 1.8 stamped on the block, doesn't mean its a 1.8. Basically there's 2 Mk1 Golf engine variations, small block and big block. The big block engines are all pretty much exactly the same externally, its only the internal machining to accept the crank (which is a different stroke) and bore (which is larger) which varies. I think (Dubboy might be able to correct me on this one, its to do with how they went through the production process) they rationalised things and manufactured the block, or produced a small variation of the block, which could be used for both 1.8 and 1.6 engines. When they did this, they also cast 1.8 into the exterior of the engine, to signify this. Later on in the process, the internal machining was done which led to it being a 1.6 EG engine or 1.8 (whatever it was - might have been DX or EX or others, eg Audi stuff) engine. At this point too, they'd have applied the engine code EG and maybe the number.
jellybelly said
how can it be a 1.8 with a Eg engine number
it just doesn't make much sence to me
I think the heads are interchangeable so you have a 1.8 head on a 1.6 block. I don't know for sure though, but nobody's come forwards to say for sure yet. Fingers x someone can solve your mystery though.
