Updated - Pg 3 - Massive oil dump - any ideas?
(In Topic #106213)
My car emptied the sump on Huntingdon ring road this morning, but I'm not sure what could have gone kaputt in such spectacular fashion, I had thought it was the sump gasket?
Most of the oil is over the offside wishbone and driveshaft (like, dripping in the stuff), but there's a fair bit up the water pump, and the drive belt and pulleys are well coated. Sump plug is in place and the gearbox end of the engine seems relatively dry.
There's no sign of any leak from the head gasket, and the water temp was normal before the buzzer went off.
Suppose the best thing to do is just to get stuck in and see what's what, but as always any suggestions or advice are most definitely welcomed!
Mat
never knew it had one
did my tits in, i just turned the radio up more lol
First time I've ever heard it and didn't realise what it was for a couple of seconds, at first thought it was the stereo, then I pooped myself when I realised.
Was probably driving for a max of about 30-40 seconds with the buzzer on so hopefully haven't cooked anything :?
still be loads of oil floating about to keep it lubed for 3o secs.
when are you picking up?
I'm not with the AA or anything you see uch:
There wasn't any smoke (as far as I noticed) and from what I could see the sump looked intact so I suppose at this point I'll lean towards Bert's idea.
Now then, how tough are those seals to replace without removing the engine?
Mat
what engine is it?
Bert
You're right though, at least the dirty bit has been done for me though
Though I'm not looking forward to cleaning all that oil off the underside of the car
tyeness said
Cool, as long as any shafts don't have to come out, it sounds OK :wink:
Get a compressor and a degreaser gun, and its a 5 minute job!
or maybe a drive through a field of tall grass would is in order (just enough to knock off ant drips.
Maybe I'll ring them on Monday rather than play the lottery on their website. Better yet I might even try VW 8O
The book of lies says I need to take the rocker cover off to hold the cam sprocket steady while I undo the bolt, is this necessary??
