buzz noise from underneath rear!
trigger said
After my constant buzz from the fuel pump yesterday i have now changed the relay that was a little wet. The problem now is that the car will turn over but not fire up like it did yesterday. Has my fuel pump now packed up? I am struggling please help!
Which relay did you change? And did you swap it like-for-like or with just another relay (fuel pump relays have an additional function in them).
To determine if its the relay or fuel pump at fault, bypass the relay by bridging the 2 large spade connectors on the place it plugs in, with a wire and switch.
1. The fuel pump was on its way out, failed, and the relay is a side issue.
2. The water has affected the fuel pump relay AND other electrics too, within the fusebox.
Either way, the test to bypass the relay can eliminate that from your enquiries. Then using the bypass, remove/lower the fuel pump cradle and test the electrical terminals on it for +12V and 0V. This will show if its the fuel pump at fault or another electrical issue.
Cheers.
