buzz noise from underneath rear!
Can anyone tell me what the buzzing noise is thats coming from under my golf? its coming from the rear drivers side wheel area, it would be a great help as I have just started her up today and want to be on the road by monday!
Cheers Trigger
That's the fuel pump mate :)
1986 Cabriolet (long resto!)
Follow us on:
It's the electric fuel pump - mounted just in front of the O/S rear wheel arch, a few people on here have noisy pumps.
It makes that buzz sound when the engine is turned off as well, does this mean it needs replacing?
Thanks for letting me know
When you first put your key in and turn it to ignition on, but not cranking it should buzz twice "prime" and then not run again until the engine is running.
If that makes sense?
Follow us on:
its been turned off for about 40 minutes and its still making that buzz!
That doesn't sound good if I'm being honest, It shouldn't be able to run without the key in because it's on a relay which if the ignition is off cuts the fuel, just incase of an accident.
Have you got a haynes manual, if so, I'd pull the fuel pump relay out of the fuse box and see what happens.
What car have you got btw mate, year, engine, tin top or cabrio etc?
Follow us on:
Technically speaking, it shouldn't buzz at all. A good condition, properly working fuel pump, pumping clean fuel, is very quiet in operation.
mine makes a buzzing noise, av done for 5 years now
1984 white s2 golf gti , 2006 golf gti
its a 1.8 golf gti tint top on a Y reg, i will check the manual now as its doing my head in and i dont want to do any daqmage to it. cheers.
Mines got a later fuse box in it (out of a 92') and I think it's different to yours cause it's got a third row for leccy windows and power hood or something so I can't help you with it's spefiic location!  :banghead:
Hope you get it sorted though, keep us updated.
Fuel pump relays are a pain, I have a couple laying about that I can send over to you if need be though. FOC :)
Follow us on:
A buzz or a hum? I suppose it depends on how loud, etc. Maybe I'm just spoiled because I've always used either Bosch or Mercedes fuel pumps (yes the Merc fuel pump fits on a VW, with a little fettling).
Mine properly buzzes as in you can feel it kinda vibrate the car, but it runs fine.
I thought all the GTi fuel pumps were Bosch anyways? (I've never had to emvoe mine *touching wood*)
Follow us on:
There's a good chance someone's bodged the cradle it sits in. There's rubber mounts to stop it making noise (by vibrating the local bodywork too) and transmitting to vibration to the rest of the car.
Ah alright, didn't even think of that, i'll have a look at it when jack frost strops trying to freeze my fingers off, fed up of messing with the car today :(
Follow us on:
I have just disconnected the battery and that stoped it, but when I reconnected it, it didnt start buzzing until I turned the key then it continued. Something is strange as the car was flat this morning and after charging it back up the mfa went mad and then stoped working and since reconnecting and disconnecting just then it is now back on! I will check it out saturday, just hope that the alarm system on it has nothing to do with the fuel.
Thanks for the help everyone just hope it will be ok, whats the damage to replace the electric fuel pump if its knackered?
Still sounds to me like your relay if I'm being honest? Did you manage to figure out which one it was and disconnect that (you just pull them out).
The MFA always mess up when you battery dies, mine says all sorts of rubbish, it was 9:59am for a good week before I dissconnected my battery / re-connected the battery :P
Follow us on:
not checked the relay, i will have a look saturday. The battery is still running low though, would this effect the pump?
Will update saturday with hopefully some good news!
The pump constantly running has probably just drained the battery, just disconnect the battery till you have a chance to look at it.
NB: the pump runs contantly with the engine so I very much doubt you've damaged it  :)
Follow us on:
it pumps twice to prime the system.  if yours is constant could it be the fuel system isn't getting up to pressure?  ( i'm prob way off just speculating).  does sound like relay though.  ours is noisy too but the cradle is just about rotted off and the pump held up by cable ties as is the rear arb.  just another couple of things on my to do list.
hello!
