mk1 caddy- project "rustowagen"
tyeness said
Quiet day in the studio dave??? :mrgreen:
You could say that! I was downstairs in the bindary for a cpl of hours helping collate things earlier!! 8O
come home from work today and see the caddy out of the garage and dad walk out with a grin on his face, wasnt sure what had been going on but was a nice suprise to see this…..
say no to seam sealer!…the bay is going to be semi smooth and simple. all the seem sealer is going (not much left now) but need to get another wire wheel or 2. just wanted to do a bit before we put the motor in. also got rid of the expansion tank for the rad as im gooing to run a big top fill rad. also going to have a nice tidy up with te wiring once it all goes back in. may possible run the wiring for the headlights around the inside of the wing just to tidy it up a bit :td no other piks im afraid but im sure thre will be a huge pregression over the week end
then with the twin 40's on
all comments welcome….
heres a couple piks from today. enjoy peeps…
before the grinder came out to play..
…and after, got to get the wire wheel in all the little places next then carry on around the rest of the bay…
cracked the welder out yesterday as we splashed on a reactor helmet so i thought i mite give it ago, didnt turn out to bad for my second attemp at welding filled most of the holes i dont need on the pass side of the bay, already skimed sanded and primerd now. just a couple little imperfections left and to sort out the batter tray area.
also half way through doing the drivers side, all taken back to bare metal as was the other side, welding as i go around. not got much filler left so going to concentrate on the other side and get that done first.
been doing a fair amount of work on the bulkhead also, had a new clutch plate put in quite a while ago so quite a bit of smoothing to get that to blend back in again, also filled in a couple of small holes and filled in a few dents here and there. still got some holes to weld up in the scuttle then should be pretty much there…
all comments welcome as usual….
anyways heres what i done after work, done a little more sanding then broke the primer out, still a fiew small bits here and there but really pleased how shes turning out now. all those hours of welding, grinding filling and sanding are becoming worth it now! enjoy peeps
What colour is the truck going to go? Black steels look sooo dirty. In a good way of course
didnt get much done just a little bit of sanding. dad went to a pipe benders today a picked up some 90 angles to start on the air ducting system that were going to make to get cold air onto the carbs which are going to have a big filter over them. just about to order that and some other bits and bobs now also got a top fill rad hopefuly ariving thursday.
heres a couple of pictures to keep the enthusiasm going sorry they are a bit poop though B)
heres the pass side engine mount after a second skim and sanding, got the shape now just needs finishing off around the corners and a few low spots here and there. will finish bot sides up over the week end i hope. not much going to happen between now and the week end though :tb
heres how she sits at the mo. it seems as if nothings left, which as dad pointed out is a good thing as parts can only go back on now which is a good way to look at things i suppose. anyways comments as usual please guys…
oh also forgot no one else pm me about selling the wellers as they have already sold, but cheers for all the interest already :I
