Project "little monster"
paul_c said
Now taken the cover off, need to check if the chain and guides need replacing or if there's plenty of life left in them.
Area B has a little wear, tapering from nothing to maybe 0.3mm next to zone A. Most of the wear is in area A, which is nearest the crank. It tapers from area B to near the end, from around 0.3mm to 0.8mm. Any ideas guys?
looks like the chain has become a bit sloppy over time maybe causing wear on the tensioner worth changing the tensioner for piece of mind
what do the chains look like? any wear on them
last thing you want is tensioner lettine once the engines in the car that would mean pulling it back out to change at a later date
you may be better asking the question of cgti
The damage
Worn but not too bad - maybe 0.4mm most of the way along its length it rubs
Another area of concern. The pink stuff is obviously coolant, initially I was worried the head gasket's gone. But on further inspection, you can see the gasket for the thermostat housing wasn't fitted properly, its obviously leaked under pressure and the coolant has dribbled down the engine
Hmmmm, those cams look way too pointy…… :twisted:
well at least you have the brains to check these things most people just spoon the engines in and worry later cant see the point myself i want to know the engine is good before i spend the time and effort to put it in
Or I could just go for a 100bhp nitrous kit.
if you want max power on wot you just tune to do it or if you want good mpg you just adjust the map bins until you get the desired afr
ms will also control nos if you want it to :wink:
paul_c said
i put a cone filter on my vr6 and had to take it off and replace it with a k&n panel filter.
the noise was just soooo delicious, i couldn't change gear any more. that's with all the acoustic dampening in a mk3!
They'd better last 40k miles!
rebuild in progress....
Anyway, I did a couple of hours tonight, just disconnecting stuff on the Mk1 and labelling it nicely, to minimise those head-scratching hours ahead of me. The pics were taken at the start of today's work so you see a fairly together-looking car, I kinda packed up in a hurry because the most humongous apocolyptical raincloud loomed overhead.
It has the feel of an ?800 Mk1 Golf GTI underneath the bonnet - a couple of non-factory wires, rusty screws, luckily nothing show-stopping though; and the Super Crack is doing its job. Once the Mercedes is sorted, I can pull it off the grass and onto the driveway, to pull out the old motor.
looks like you have hours of fun with a mig welder :wink:
