Project "little monster"
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
Hairyarse said
What type of paint are you using Paul?
Oops, didn't notice the thread had moved on. I originally painted stuff using rattle cans, but now I've bought a compressor I'll be reaping the financial benefits of proper spraying (the paint works out much cheaper in the long run).
The primer or stonechip is cellulose, the metallic base coat 1k acrylic and the clearcoat is 1k acrylic too.
Hairyarse said
Can you mix the use of acrylic and cellulose with no problems? Which is the one that's really bad to breath in?
You can spray 1k acrylic over cellulose primer so long as its cured (ie a couple of days after its sprayed).
The one that's really bad (ie fatal) to breathe in, is 2k acrylic, it uses isocyanate. Having said that, I sprayed the cellulose primer on without a mask, then a few days later had a bad case of diahorroea and vomited a few times too, but I can't say if it was down to the fumes or the kebab I've had.
So, I went out and bought a respirator (about ?18 ) just in case.
I've just sprayed 1k acrylic tonight, and I am still alive, I'll let you know if I get the runs again though.
Cheers for the info, will be a while off yet but whilst I'll get a pro respray done on mine, want to spray the under the arches and engine bay myself, as no possibility of sending shell out only - need the wheels and engine in the car to get it out the drive! (Very steep and tight access)
Hairyarse said
Probably the kebab!!
If I were to recover an immobile car off a steep/tight drive, I'd use a solid bar - are you sure it couldn't be towed like this?
Not saying it's impossible, but wouldn't be easy as drive is off a narrow lane so you can't tow straight out the drive, in a straight line if that makes sense?!
I'd be very wary of doing a respray without taking the wings and doors off and glass out. Masking off interior and engine bay is fair enough.
you never make things easy do you!! :wink:
So, after a long time scraping and cleaning this off, with a degreaser gun, plenty of blue roll and an old toothbrush, I was able to wire brush any rusty areas (thankfully few) and spray on a zinc-rich primer:
Then today, I sprayed on 2/3 coats of stonechip, using the proper gun:
Also I have cleaned up the alternator, at first I degreased it but this didn't leave it good enough looking, so I've spent hours and hours with wire brush attachments, from a large brush on a power drill down to tiny brushes on a Dremel:
ashtray said
ok right cheers, i got coil-overs all round height + damping but with the extra weight i am worried the springs will need to be a higher rate? would you say the extra weight would be 60kgs ish?
No idea really….60 kg is as good a starting point as any, though.
paul_c said
I'm going to try coilovers at the front and stock GTI stuff at the rear, as a first guess.
uprated coil over springs and stock rears??
Brake upgrade. As stated earlier, I'm using a Mercedes W124 master cylinder and servo. As can be seen, its much larger than the stock component, or even a 9" Mk2 GTI 16V item. The clevis pin fitting is the same, but the rod is 20mm shorter and after a bit of trial and error the easiest way seemed to be to chop this out of the bracket on the left.
New servo
Old servo
Comparison
I've also been attending to the bodywork. Here I am working on the floor section on the left of the car:
How long do you reckon before this beast is on the road/strip?
