Project "little monster"
Anyway, took advantage of the good weather today. I wire brushed the main rusty areas and make a few corrections with the grinder too. Then used the pressure washer on it, then dried it, then scrubbed with degreaser (some areas using a toothbrush). Finally it was ready for painting. I have applied stonechip, I'll be applying silver topcoat then lacquer once its dry:
I wanted a break from cleaning and bodywork, so I looked at the rev counter issue. Obviously, with 6 cylinders the impulse for the rev counter signal is 1.5x what it would be for a 4 cylinder engine, at a given rpm. Now, its a little-known fact that the rpm reading is adjustable. So I took apart the instrument cluster:
And once the rev counter was out, found the variable resister which does this adjustment (see arrow):
I was able to trace the circuit path on the backing flexible circuit board and look at the terminal connections, in conjuction with a wiring diagram, to figure out the 3x connections on the back of the rev counter:
Then I made up a little loom, and connected it to another car (+12V, earth, impulse from terminal 1 on coil):
I adjusted the rev counter down so it reads more/less correctly, by also connecting a multimeter and putting it into 6 cylinder mode. In fact, I ran out of adjustment so its still a little high, but it will do for initial starting and checking. Later if needs be, I can program the ECU to output a revs/2 signal and there's loads of adjustment upwards on the variable pot.
Here are some parts which are getting repainted:
Here is the inlet manifold, being wire brushed clean:
it's a boring old job cleaning and painting but well worth the results.
keep up the good work
83 MK1 GTI G60 85 MK2 GTI 20VT 2004 SEAT ALTEA 2.0 TDI SPORT
you gna give it a good polish or have it like brushed metal?
Here is the steering rack all cleaned up, painted, and fitted. Also note the fuel lines roughly in place:
The fuel lines now have their rubber spacers on and I have also replaced the brake pipe which will be inaccessible when the engine is in, and the heater hoses and grommet:
Its getting through all those other jobs that keep on turning up, just as you think you've finished something 8O
Pete
as can be seen, the fit 'out of the box' isn't too great (not that bad either) so I'll do a little fettling before its painted.
Good luck with getting the wing straight!
WOW
:clap:
