Project "little monster"
It looks like the chassis leg is in the way - so I'll be chopping some of the width out of it and using a thick plate to close it up again - just need to find a steel merchant nearby, who'll chop the min 4m length in half so I have a fighting chance of getting it home!
The other option is to go for "version 2" driveshafts, getting an even shorter left one made up, and a longer right one. But its simply too costly….
I've figured out the mount on the gearbox side, I'm going to make custom brackets up and reuse the rear engine/tranny mount, it works out much more compact than the VR6 mount. Front mount should be relatively easy. No idea about the engine side mount yet, though.
1989 VW GOLF GTI CABRIO
1997 VW POLO 1.0L
2003 VW PASSAT TDI 130 SPORT
1997 VW POLO 1.0L
staffords said
Paul, i've got access to a laser profiling machine if you need any complex steel shapes cutting for you just to weld together (custom mounts etc) can cut between 0.5mm to 20mm thick plate quite accurately. 8)
is this an open offer mate?
not quite an open offer, if i can help out i will but i don't want to 'abuse' the situation :wink:
1997 VW POLO 1.0L
1997 VW POLO 1.0L
i just need three pieces of 6mm cuting pal,
1997 VW POLO 1.0L
1997 VW POLO 1.0L
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=230172791402&ssPageName=STRK:MESE:IT&ih=013
http://www.deist.com/c…?category=501252021021875
I need to get a key on what my 1/4 mile times will be, apparently they come recommended fast than 11 sec runs.
BUT was just thinking wont the mk1 be very nose heavy with a vr6 lump in it when finished?
crazy_timmy said
power to weight ratio will be amazing when you finish,
VERY
VERY
Scary - it may end up almost as heavy as a cabby!
im still looking for a 76 shell to spoon my cabby goodness into oh well the search continues
bens_cab said
Nice video! Cheers for that one!
(PS my personal best time is 14.15……I think the lack of spoiler, makes the difference)
VERY
Plenty of food for thought here:
http://www.dragstuff.c…les/weight-reduction.html
Use Velcro for mounting most of your electronics
Remove the ashtray
Carbon Fiber nuts are now being produced
Use water based paint.
Remove all unnecessary junk
Run alcohol
consider putting your own body on a diet!
Dump your pocket knife
Find a petite ?pretty? girl
Well, only a little mod. I'd previously chopped the door frame off at the bottom and made a ramp, this proved to be inadequate when the engine crane holding the VR6 was on it. So I've upgraded and widened the ramp, to be wide enough for the engine crane, so I have a fighting chance of getting the engine out of the shed.
