PROJECT "DOG"
HERE SHE COMES
Well she has here new coat,and looks a little better if i do say so my self
thats me by the way
Time to start sanding again
colour sanding,im sick to death of sanding,but all adds up to a good finish,as you can see ive bought here home again,just easier to work on here
first sanded with 1500grit and then again with 2000grit im knackered
FLOCKING
FLOCKERING,i here you say….what is that?well i was looking for some "b"post seals that were not completly worn out and could`nt find any,but i did find some that was not split (result) so i wondered if i could reproduce the texture on the seal that the windoe glass run up and down on,and i come up with flocking,and it works really but don`t use the glue that the flocking companies recommend,i have try lots of stuff and here the best i have found
first remove all the the old stuff and scrubb up the rubber so the glue has a good surface to bond to
then find your self and old mk1 bonnet outside to work on, and apply a mixture of glue and black paint
mask of the seal,and glue seal,then with your flocking in the dispencer cover the seal well,this is messy
i bought a 2 oz bag a dispencer for about a tenner this in more that enough,i did six seal with plenty to spare
leave for at least 72 hours to dry then shack of excess
i think you might be impressed with the finish
sorry about pics car was still in garage
some more pics
getting wiring loom in and windows weather alittle bad to work outside
looking very good,are you going to change the wheels
<a><img></a>
good work will look the  D.. BLX    when finished :wink:
Mk1 2l TSR G60.  .getting. There twice as fast
8O  Blimey
If you need a engine let me know, as i have a 1.8 carb engine you can come and take for free!
yes i am changing wheels,they look abit nasty i think,plus there bent
funk-star said
8O  Blimey
thanks for the offer,but i have a donner car which im using……thanks
loom
after reading other comments about cleaning wiring looms,i thought, i woud try the dishwasher method(WORD OF WARNING)do it when the wifes out,this method worked very well,just required small amount of work when finished on a hot wash…as you know cooper connectors tarnish after time,so every connector was left in a jar of lemon juice which bought them back to high shine and removed any corrosion,then covered with electrical sillicon grease to prevent futher tarnish.
Great Effort
Looking really good..Yeah thise wheels need changng..  Looks real good so far.. Keep up the hard work..Did you say this car is for your misses…/
Re: Great Effort
yes its for her mid life crises,when shes forty…so only 2years left,better pull my finger out
headlamp relays
 i know its alittle over kill,but have added relays to both dipped and main headlamps,so with abit of look they should stay bright
flocking
the "b" post seal with the new flocking,has work better than expected,now i can run the window up and down it,it has stuck atreat,and looks great worth every penny
looks fantastic mate, how long has it taken you to get it to this standard?
its been a good year or so,just having problem with putting the time in..what with work,and family
