project lead foot - resto underway!!
YOU DA MAN!!!!
your dash and gauges are awesome.
you have a good eye for detail
what are you doing in the way of engines
keeping the original or going 16v like you wanted before
shout me
yeh im goin abf, by the looks of it itll be runnin before yours hahaha. got sum goodies on the way too me for it.....pure dench!
mk1 golf - resto
mk3 polo breadie - daily banger
the war on rust continues, after replacing the n/s chassis leg i was guna remove the exhaust mount hangin bracket thing an put it back on but it was too crusty for my likin so i thort id make a new one… might as well do the other 2 whilst im at it as they aint lookin to keen either.
i started with the mount that lives on the rear chassis. i call it the RUSTACHE.
i bought a 10mm steel rod and heated with the oxy acetelene and bent into shape. welded abit on the end to stop the rubber mount coming off. should av jus heated the tip up and hammerd it up.. durr.
i had made the other two but will prob do em agen to make the curved end abit better.
then i welded this dozzey to the chassis
got a facet low pressure fuel pump for the carbs deliverd in the week, guna run a carb lift pump from a cabby to this pump.
welded two bolts to the rear axle mount to mount the pump on.
bingo
mk1 golf - resto
welded in the boot floor this week, jus needs grindin back, yawn.
mk1 golf - resto
aftre grindin back all the welds on the boot floor i cut out the rear seat pan and tonight i got the new panel tacked in, will hopefully get it welded in this weekend, twas a right pain to get to fit right as the new panel came with the seat pan raised up bout an inch so had to cut it and get it level with the boot floor the beat it flat and together with the boot floor and now weld it.
mk1 golf - resto
tacked it in all round then i ground all the tacks flat.
then welded all around
still got a bit in the corner too sort out
need to fill this bit
with this bit
and put abit in here too then grind it all down.
mk1 golf - resto
trimmed this corner bit an tacked it in
then welded it in.
mk1 golf - resto
got some enigne bits in the post today from techtonics tunin in the states. still waitin for my pistons to come, will soon start the engine build. need a few more bits first though.
new valve guides, spring retainers and stem seals
heavy duty valve springs
set of lifters
con rods
vernier cam pulley
set of 276 degreee cams
mk1 golf - resto
got another piece of engine in the post today :)
a set of wossner pistons! 83.5mm , 12.4:1 compression ratio. these things are guna pump!
no stickers though :(
mk1 golf - resto
What's this car looking like now mate? Excellent write up and detail :)
its coming along slowly but nicely, been having to faff about with metal fabricators to try an make me sumin with out it costing me an arm an a leg so thats taken up alot of my time. update soon though!
mk1 golf - resto
hi,
small update here, finished the boot floor by fittin a home made sparewheel well as mine was of course well rotton. i was guna get one made for me but i was quoted like 200 quid so i thort id make it my self.
got a disc cut the size of the hole and a strip of metal to wrap around it.
i made a wheel well shaped template out of two pieces of chip bourd and sun bist o wood in the middle. ti then ratchet strapped the strip around it and tacked it all in place then i removed the wood.
i then bent down some tabs for it to sit on the boot panel with and to be welded.
i wanted to put the battery in the boot but didnt want it on show so i made a recess in the floor for a battery to sit in. was a pain gettin it right so the it fit in with the spare wheel. was very limited for space so if the battery is too small i gess i will ahave to have it out on show!
now that bits finished ive put it back on the jig so i can sort out the last bits underneath. been off the jig for a year!!!!
mk1 golf - resto
Love the pattern for the wheel well, and the battery storage is genius, good thinking!
look whos online..
like the wheel recess youve done..
haha i cant stay away. we need to get a multi meter on ur car an test the feeds an grounds to that immobiliser fing!
mk1 golf - resto
still welding… yawn, slowly…. yawn
made my chassis rails that ran along the floor pan from the wishbone mounts.
got the fabricators to fold us a chanel, i then welded the wishbone mount on and cut bent welded the other end up.
old and new
on the car
i also got a cupl new fuel tank strap mounts as i had misplaced mine…. made a sandblasting cabinet thing at work out of a bin so i could blast these.
welded in
this is guna be my gear stick nob. its a beer tap handle my mate nabbed me from cyprus. already has a thread init but i think it will be too small so ill have to drill it an tap it out
got a new rear arch liner, this is the old against new. i made a new nouting bracket for it to bolt to in the inner arch as the old one looked too crusty for my liking. just need to drill holes for the screws.
that is all for now, would like to say there will be more progress soon but my welder has packed up so need to fix that first!
mk1 golf - resto
I've just read your build and I think your mk1 has been through a rough time but looks like its starting to come together. Will be a very solid car :)
Mk5 golf tdi daily
Mk1 golf project
Corrado vr6
2.0l 8v beetle
best gear knob ever!!
yeh the poor old girl was abit abused it seems, all will be wel soon tho hopefully. manged to fix my welder tonight by replacing the wire feed line asit had become blocked an wouldent feed wire through it. can get sum wrk done agen now… he ses.
gear knob is def a gooden, new i had to have it wen i saw it. is the right colour i wanted the interior to be aswell! score!
mk1 golf - resto
Wow that little golf has had more surgery than michael jackson eh shamon mo fo lol,difference being when its finished it wont look like some kind of circus freak haha.Thats some blood sweat and a lot of tears il for you i bet! Got to admire the hours youput in fella i applaud you.
