Papyrus Green Bermuda import
charlie-says said
I'm not a fella! People always call me fella on here. Sadface.
Lol typical blokes always assuming girls don't love cars as well…can only apologise
keep up the good work
1.8T CABBY
1.8T CABBY
Now this boy has a bit more work done :mrgreen:
Got Mike the polisher to re-polish the chrome strips on the grill so fitted them back on tonight and re-fitted. Also given the front panel is repro the headlights didn't fit properly so had to grind the outer metal on the headlights to get em to fit.
So a night in amongst the midgies I finally got all the carpets out as they had been left uncovered during the prep for the car (in the middle of this I coulda killed the painter :mrgreen: :twisted: ). Believe me a hoover wouldn't touch these . Also re-discovered how difficult the retaining studs are to get off.
How bad they were……ingrained with sand, filler, paint etc
A bit of before and after
Roof fully on now and finally got all the straps re-attached. Have a bit of cleaning to do to the lining as it was sat outside all winter (covered)
Also got the drivers qtr light in. Ball ache given the new seals and the chrome trim, but got there…..just need to get the other side done and we have glass all round
Got time to get the wheels across to mate Gerry to get the tyres on
yes……still to adjust the ride height
More tricky was fitting the door cards. These are very early door cards and as such took a very different handle, which I can't source so had to adapt them to take my existing ones.
First was to remove the retainer that the top of the handle clips and twists into. Shown on 2 different door cos I'm a fanny an forgot to take pics
This shows it where it normally sits
And once out the sleeve, filed down and in the alternate hole
And some nice clean door cards re-build and on
Anyone a bit older may guess where the winders came from……not VW 8O ??
Finally managed to fathom out the vacuum hose set up…..I think….so engine nearly done
How does a car get imported from Bermuda to Scotland there is bound to be a good back story there :dontknow:
My New Year's resolutions are: 1. Stop making lists. B. Be more consistent. 7. Learn to count.
It's now a 3 owner car Registered in 1985 and imported in 2001. Up until last year it still had the km only speedo, has never ever had a fog light fitted and has only covered 56,000 miles now it's been converted. I've still got all the original paperwork and docs showing it was sold by Masters in Bermuda. I've googled the first owner and he still lives in Bermuda so once the cars finished I'll mail him a few pics
New BBS caps arrived so got em on. Also had a look at dropping the front down a bit, but helper springs will need to come out for the chop
Also had my Audi chrome handles turn up along with the chromed armour door plates….so stuck em on…and I like
Had picked up a powder coated rear beam ages ago and had all new brakes etc so time to get em all fitted
One bare beam
One part built beam
My mate crawlin under a car
Also took time to replace the filler neck and also stone chipped the whole underside while the beam was off
Took the helper springs off the rears before we started, but even running this high (want lower) the spring isn't seating at the top so took em back out to see if the helper springs will still allow lows. RS's look much better with the 20mm spacers on tho :mrgreen:
Had an issue when putting the rear beam on as I heard some dripping…..nah gushing….looked down the underside of the car to see the fuel tank emptying itself on the drive.
Now I had repaired a leak last year for DC11.5, but since then they have rotted through completely
Once cut and ready for sleeving
Sleeved
And back in place
Should be good for years to come and more supported than the std metal pipes on their own
Then to bleeding the brakes and as is typical a nipple sheared and then the bolts were so rusted that we couldn't get them out the back of the cylinder so outwith the grinder and boom :mrgreen:
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
R32GUY
1992 Rivage in Classic Blue Pearl "B16YUG" 2.0 TFSI, 6 Speed FWD with Quaife LSD, running on Air with sorted geometry and Eibach ARB's, G60 brake setup front and rear, 4x100 17" BBS LM's, Power Steering, Opening Quarter-lights, Mk2 electric recaros and the whole car trimmed by MJ Interiors in tan and Alcantara with a brown roof.
and made some repairs to this so we don't have any fuel leaks
Got a windscreen man in to fit the screen….looks braw
With massive amount of love going to a mate Roy who spent most of yesterday trying to get it running. Time served VAG tech and found loads of issues with the 2E3 but eventually got it going ok
clicky….still running a little fast on idle, but I had to drain some of the coolant to fix a pipe so may have an airlock
R32GUY said
Great build thread, and lovely colour too!
woody83 said
looking pretty sweet really fancy a set off small bumpers for mine
Hadn't seen many cabbies with small bumpers and thought why not
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
allana13 said
I like your choice of painting the engine Gold. Makes a change in it
Thanks. Was looking for something that worked with the green and it was either gold or silver so opted for gold. The polished head would have been great, but the tappets and cam are wrong for a straight swap so need to source those at a later date :cry:
1.8T CABBY
1.8T CABBY
richyhill said
looking awsome mate, cant wait to see some pics when its all done, what are those wheels you have hanging up in the backl of the garage? :-)
Thanks.
Wheels at the back of the garage are a set of 5 x 19' BBS LM's in Celeste Phoebe (Lambo colour given I have Gallardo brakes and steering wheel on my W8). The W8 is waiting for a new engine which I can't do till I get the mk1 out the garage hence the rush to get it finished Long q to get in my garage :mrgreen:
