new member mad idea ,mk1 caddy 4motion 4wd turbo 24v......
no ,,but i will make it fit ,,,lolbouchay said
Will the mk1 indicator stalk and wiper stalk fit over the corsa steering column?
then made some quick brackets so i can mount in the same oringle bolts holes saves chopping the dash frame to bits
roughly how that bit looks
then as mine was and adjustable coloum had to weld a coloum in place so i can use the mk1 cowling and switchers
then bolted the lot up in place
everything fits nicely ,
regards the u joint i split them and simply changed the ends so they clamp up nicely from the rack to the coloum ,and the steering wheel ,i cut it off ,put both parts on the lathe and stick welded it and drilled and peged it ,,,
only thing the under tray i had to nip a bit out for it to fit ,,,
thats the steering sorted ,,
i wish ,its childs play/fun stuff ,3hour job done ,, nothing hard tbh ,theres no need for fabacting mounts to std mk1 dash ,as there aready there ,just 2 simple brackets , so you have 6bolts holding th coloum on 2 rear 2 centre and 2 under the steering wheel std holes/regards the splines ,looks like it will fit but it dosent ,u just get the vw j joint and the corsa u joint and change the 2 ends re tap the pins back in ,sorts that out ,and the top ,i had to cut the coloum the tapper it on lathe ,cut old top of coloum rowters that out ,then drilled and inned it and welded around it just to make sure its not going to break ,, nothing to them ,,, :wink:bouchay said
I'm officially jealous of you, of your skills, tools, and what you're building 8O What were the main headaches of the steering rack conversion? You make it look so easy, keep the cracking build updates coming! :mrgreen:
wear abouts in donny are you by the way armthorpe, intake?
i live in scumtake lol cant leave my tools while i get my dinner without them gettin twoked.
do you have any idea about seam welding as im in need of some advise lol
gaz
keep on dubbing
im approx 7 mile from ya ,i know intake a few freind liv other that way ,,its just fun stuff ,cut chop and make it fit ,,cheers ,what do u want to know regards seem welding if i can help fire away,,,gaz_mk1 said
you are so modest mate you should be an engineer iv done 3 years at college doin the mechanics course and i still wouldnt be able to do stuff like that but it could have somthin to do with me smoking weed lol cant think without it.
gaz
i looked at doing this but lack of space ect stopped me i reckon your right with the cut weld cut weld its childsplay tbh and anyone could do it if they bit the bullet and got on with it
your an inspiration to lots on here for the way you get stuck in :wink:
cool reply well if anyone wishers to donate ill be glad to do it ,,no problems at allbens_cab said
right for your next project id like to see a v6 bi turbo audi lump fitted but with a twist rear wheel drive
the main issue is getting a gearbox to fit but i reckon i could use a cossie one and get a bellhousing plate made to match it
i reckon a bi turbo would be a chuckle on the strip wheel stands of the line
plus i recon 600bhp plus just for good measure
it will be interesting to see what the caddy is like all done i reckon it may go a bit
keep up the good work
yearh that be fun ,just make a adaptorplate to suilt ive done 4 now all work fine lolbens_cab said
this is still in the pipe line for the future
regards caddy ,anything could happern but im willing to try lol
quick pic of the controller which will work for varible steering ,ie light or heavy
not take long to wire this buggar up just to try it anyway ,as its like a tank to steer at mo lol
Ive just been pointed in yr direction by Bens-cab. Truly inspirational.
I bow to your expertise :notworthy:
Can i be your bitch??
Keep it up mate im watching this build with eagle eyes now 8)
right guys thats the steering sorted wired it up 2day and it works a treat too ,evern the heater hoses fit back nicely after fitting the moterized coloum ,looks like it was meant to be there,,
and sorted the electrics out on the car ,all working too ,,anther job out the way
just checked old instrument pannel things worked and they do just front incadtors to sort/ as light is staying fadly up on dash when hazards lights are off
and ill have to adapt a differnert speedo set up too as mine has to be electronic
and marked all the rest up too ,#
i want to try to wire the engine up to get it runing for christmass…
yep ,piece of mind that the engine maybe ok ,,,lolPhoenix said
now that would be a happy christmas
then started on the shorter runer intake
Did you sort your indicators? I have the same problem. Any suggestions?
