My Resto 1982.... New engine start videos.
My Resto 1982.... ENGINE START! With video!
Mk1 Golf Gti Abf conversion Project
Mk2 Golf Gti 16v
Mini Cooper S R53 (Daily)
Mk2 Golf Gti 16v
Micro switch for the demister fan and heater
Decided instead of having my new system switch between the face fans and the demister I will just make them separate. So the fan speed switch now will just control the face fans and this micro switch with switch a relay on and turn on the fan for the demister and heater when you slide it into that position on the slider.
Bought some resistors for the speed switch as well. As the original one wasn't up to the job. Didn't reduce the fan speed enough for my liking so got some high resistance ones.
Mk2 Golf Gti 16v
Also got sent some wire interference shielding for FREEEE. lol. Just emailed a company i found on google and they said they would send it to me for free. 25 meters of it.
Mk2 Golf Gti 16v
Very close to finishing the wiring now. Just need to connect up the oil temp and pressure sensor wires up. I wired them up to the gauges but need to feed them through the chassis to wire them into the sensors. And I still need the pressure sensor. I also wired in the face fans and the demister fan and put in some wiring for the speakers.
Here's a shot of my finished fuse box with all the extra fuses and relays. Quite a few extra lol.
Mk2 Golf Gti 16v
Modified the plastic vent that attached the air box to the screen demister vents today and fitted my new air vent with the computer fans attached. Thanks to richievr for the air vents!
Before
After
And fitted the micro switch and it works.
Need to weld up a bracket to hold the motor.
And i fitted the aerial.
Mk2 Golf Gti 16v
Mk2 Golf Gti 16v
ECU in the cubby hole so I can still get to the connection to connect my laptop up but still mostly hiden.
Also got the rev counter working. Have to use the coil side of a relay to mimic a ignition coil output inline of the output from the ECU. Bit strange but it works.
Mk2 Golf Gti 16v
And I drilled a hole in the side of the throttle bodies for the air temp sensor. The plug sticks out a bit for my liking but it will have to do. Nowhere else it will go.
Mk2 Golf Gti 16v
Fitted the pressure sender for the gauges.
And started wrapping the loom since its now FINISHED!! Looks pretty cool like this but this is the shielding.
Mk2 Golf Gti 16v
Big Lew
Little Christmas present for myself. Need to stop spending money! Woops! Missing a bit of glass but got for a bargain. Some would say bargain anyway.
Mk2 Golf Gti 16v
Will the Screen shielding on the thoses cables be grounded?
Mk2 Golf Gti 16v
Good to hear… We uses these at work which will make you job alot easier when trying to ground all thoses looms..lukeybabes said
Yeah it will be grounded.
Hope this helps…
Mk2 Golf Gti 16v
Solder sleeves.. They give your screen a good hermietical sealed joint to enable a good ground point..lukeybabes said
What are they? I'm only using the shielding on the sensor part of the ecu loom anyway.
Mk2 Golf Gti 16v
Gave them a clean. They are the stick on type so need to buy some proper glue. I hope they still sell it in VW. And I hope the clip thing that holds the windows shut some with the bit that sticks on the window from VW heritage. Otherwise I have no idea where I'm going to get them.
Mk2 Golf Gti 16v
