My mk1 resto
My mk1 resto
cheers, boyle
mk1 golf - resto
mk3 polo breadie - daily banger
if it\'s got tits or tyres it\'s gonna be trouble
boyle_sbd - they are dellortos… can get the jet details if you need them? crank case breather is on the front of the block beside oil filter attachment
mk1 golf - resto
1979 S1 MK1 Golf L FOR SALE! http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=101471
1970 VW Beetle 1600 Twin 34 ICT\'s - Betty
1973 Marathon Beetle - The Moll\'s
Got a couple more trophies last summer and have been enjoying driving it it is loosening up well and is very torquey!
Little pic taken by photographer at the show:
With a combination of different engine, different gearbox and original 1.3 driver clocks and despite trying all the drive cogs on the cable the speedo still read too fast.
So fitted a GPS speedometer from http://www.digital-speedos.co.uk/ds100-gps-micro-speedometer-259-p.asp
Just mounted this on the dash and it is very easy to read and only needed a live and an earth! original speedo was over 10mph out - this records miles and max speed! and is very accurate! great job!
And a general dash completed pic - also mounted the fuel toggle switch on the lower right of the dash and it is illuminated until switched on and is one of the covered ones!
Next up is some form of front anti roll bar - not sure i can run the normal one due to exhaust diameter and four branch etc… have a few ideas
Will update as i make progress!
Wšrthersee Tour 11
Wittenberge 08,09
Rothenburg 08
Schafflund 07,08,10
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=111433
Wittenberge 08,09
Rothenburg 08
Schafflund 07,08,10
Good job on the electronic speedo to, mine is out to, but under reading!
Dash install looks nice and tidy to.
Andy im not in Lisburn… Get a build thread going of your new purchase…
Can I ask what size/type of fuel line and fittings you are running and length would be great as well,
Where did you get them from
Carbs4ever said
I can't recall the exact size. I got it from a Motorsport shop in Ballymena. They had carbs there in the shop and just matched it to the fuel union.
Cheers, think I will go with 8mm/AN6 as that seems to be the standard size I have seen most.
Truly inspirational…
1.8T CABBY
1.8T CABBY
