my 1983 tin top gti metal work started
hello everyone thought would start this thread on my resto.
hopfully at the end of it i have a rust rattle and squeak free car  :lol:
well only just got my golf but got down my workshop for a few hours the other day and started stripping
as you can see found a few holes but still nothing to major at mo
<a><img></a>
Let the fun begin!
yea should be a good!
can anyone sugest the best low profile tyres for my p-slots?
<a><img></a>
looks like a good shell, hope you dont find too much in it.
good luck with the build :D
yea its not to bad got to thank the champ who sold it to me he made all problems clear with it . cant wait to restore it to it former glory just got to find the time really  :lol:
<a><img></a>
manged to get a few hours in today on the golf. need to sort the workshop out so i can start striping fully but until i get a spare day to do it will have to do some of the other smaller bits so decided to clean up the bonnett
so here it is to start with
as you can see from the pics but was some quite badly rusted bits so out with the wire wheel and a helping of this stuff >>>>>>>>
and ta dar back to bear metal
looks loads better :mrgreen:  so stuck rust eater on the really bad bits and left it to do it magic. hopefully get down there tomo to primer it up
<a><img></a>
Be sure you have no nitromors left, or you'll have big trouble when you paint it.
will do that was the only thing i was worried about it said to clean of with water surely that would just cause it to rust so i used thinners  :?
<a><img></a>
Yeah, probably your best bet using thinners.
well got back to work on the beast today as finished early. on monday i managed to get a coat of zinc primer on the bonnet
and also 2 coats of filler red oxide primer on there
today managed to get a couple of coats of primer on there
then i decided to re-bolt it to the car but that just made a new problem
FINAL COLOUR OF THE CAR ! i like the red to much to get rid of it so think that will be final colour
while i was waiting for bonnet to dry before putting it on decided to remove sunroof to find
so have to wait till get interior out to fix that one dont fancy setting fire to anything welding it up
getting my rolling jig soon so can crack on properly
<a><img></a>
And he's off!!
Good start bud! nice job with the underside of the bonnet..not looking forward to tackling those braces next year.
The rust doesnt seem too bad though. Athought when welding the sunroof, frosts restoation do stuff called cold front to help prevent your panels warping. you probably know but its always worth mentioning.
Think you'l have fun with this one! !
I'l be keeping an eye on it.
All the best with it fella!
thankyou for your comments mate
how does the stuff you said about work is it like a paint or like a pipe freeze sort of stuff never heard about this stuff before ?
<a><img></a>
its a hard one cause i really like the colour of my garage door and think it would work well but then i really like the oxide so really dont know what you guys think
my door
<a><img></a>
sorry took it earlyer when weather was bad its a choc brown colour maybe very slightly darker then milk choc
<a><img></a>
well made a start on the rear valance today was a bit daunting going at it with the grinder but heres how i got on
well heres the reasons why i wanted to replace it
so first off placed new panel on top and marked round to give some idea on where to cut
any ideas on what the little hole marked with a ? is for
then i took to it with the grinder started by removing the bulk of the panel
as you can see i left the parts round chasis leg as didnt want to chop into them . so to remove theses i started buy removing paint and then marking spot welds then drilled them out and they fell straight off
and there we go tryed new panel on for size not a bad fit but needs a little chopping will be welding it on tomo after sorting out the rest of the rust under the panel
<a><img></a>
sorry so long buddy!
cold front is a putty that goes around the area to be welded.
soaks up the heat to help prevent panel warp.
no worries stuff sounds idea will defo have to invest
<a><img></a>
Good start on the rear panel.
Is there a lot of welding to be done?
Pete.
