Mk1 GTI Blue G60 Conversion
Looking to get a repair done on my rear quarter, after seeing your inner quarter I may need to do a bit more work than just patch up the outer quarter with the repair panel. May need to do a bit on the inside too. What do you reckon?
Fancy coming down to do a bit of touch up on mine lol!
Wanted: Front Bumper, DESPERATELY NEED A DRIVERS WING!
MY Build Thread
My Facebook Build Page #Project83
Hairyarse said
That's coming along nicely
Cheers mate!
watson said
amazing rebuild, love all the attention to detail - top work.
Alfie said
Wow dude, just read your whole thread! Amazing work! Massivly envious, who did your paint?
Nice try, I have enough on with mine
Thanks for your comments
A guy called Steve did the paint, his company is A-List in Norwich, I can thoroughly recommend him they did a superb job and he is a good fella.
Your rear quarter looks very similar to how mine did, rotten with a fair bit of filler already in it. I think you will need to do the same as I did and get a replacement rear quarter and cut it out so you can use the complete repair panel. This will give you enough room to be able to repair the inside part.
I have been following your build thread and thought it had already gone in for paint?
Cheers for the advice, the car went for paint and welding this time last year but came back worse than it went in, so I had to start over, not really got further than stripping it down. After seeing your floor i'm going to book mine in to get the underside blasted. It looks good, but I don;t fancy leaving it to chance that it's all sound undernearth
MY Build Thread
Blasting is definitely the way forward, so glad I had mine done as will uncover any hidden nasties. Make sure you scrape off all the rubbery under seal before hand, if not the blaster will have to use very course grit which could end up causing distortion and unnecessary damage
Melteddrummer said
Engine bay looks great Jimi are you going to be partitioning that cone filter off? just thinking of heat coming off the engine, that's all.
Hi Andy, it had crossed my mind. I may partition it off, I've seen it done before with the g60 conversion due to the filter running back along the engine. I will see how it goes, there is plenty of open space underneath for fresh air to come up to it.
Melteddrummer said
True enough, never thought of the air coming up from underneath. Me and my mate have just took the cone filter off his ST170 as it was drawing hot air in, that's what made me think about yours.
I know what you mean, I remember when I had a 205 1.9 gti and I borrowed a cone filter off a mate to try and it performed terribly as the location was close to the bulkhead and I didn't have any air hose to duct to it. The heat sink was awful. Needless to say I gave it straight back to him and put the standard air box back on.
looking great as always
I have a few questions, what induction kit and alloy pipe are you using (Bartek)?
What battery are you using? Odyssey?
Rich
RichG said
Hi Jim,
Rich
Hi, Rich
For the intercooler piping I bought a variety of alloy and silicon pipe/hoses and adapted them to fit.
The air filter and pipe from filter to charger came with the car when I bought it so not sure on that.
Yes the battery is an odessey
Jimievo said
RichG said
Hi Jim,
Rich
Hi, Rich
Which Odyssey? Cheers
How are you getting on?
What did you mount the 2 metal coolant pipes to ( the large one from the bottom water pump outlet and the smaller heater matrix metal pipe?) I notice on mine there are 2 metal tabs with captive nuts.
RichG said
Hi Jim,
Hi Rich,
Slow progress at the moment due to electrical issues so engine is yet to fire up .
With regards to the water pipes, I have a flexi pipe running from the bottom of the water pump to the rad. The metal pipe which runs close to the side of the head is secured by a metal tab coming off it that is secured with a nut which goes on to a bolt with a stud off the end which secures the plastic coolant pipe flange to the side of the head.
New carpet installed
I made some new rear/boot cards by jigsawing some fibre board and gluing some material to it.
Front grill fitted, I made the air holes longer to match the intercooler and even further to the drivers side to allow plenty of air the air filter!
Next up I decided to pull the speedo apart and clock it, as virtually everything on the car is new anyway. Except maybe the speedo itself lol.
Door cards installed
And lastly rear part of cage and seats installed, this wasn't so straight forwards as with the cage in there wasn't room for the upper seat belt bracket to bolt to the B pillar, so I had to order some threaded bosses that I welded to the roll cage and the belts work rather nicely now. I didn't want to go down the harness route.
Thanks for looking
What are they from?
My Build Thread
