Mk1 GTI Blue G60 Conversion
Melteddrummer said
Wowzaz car is stunning Jimi, more pics please mate once you get some more bits on!!
Yeah, will do! How is yours doing? Has it gone for paint?
smudger said
Goa? How the other half live eh Andy
Yeah, my mate got married there to a girl from Goa. The wedding was like something from a Hollywood movie
Rear brake pipes installed.
Fuel tank, lines, pump and accumulator fitted.
Some more parts back from the platers! Even though I had told the guy twice that I wanted them yellow as per my previous parts he had done somehow he still managed to do them silver! not a huge problem, had I have been doing an original, standard restoration I would had to have had them redone, but I can live with them as they are.
And lastly rear beam fitted! All bolts torqued, bearings adjusted and handbrake cables/lever fitted and adjusted. The coilovers are fk that came on the car when I bought it, they haven't done much work and will do for now.
Thank
Are you having a manual one inside the car or something?
Yomp said
Something looked odd with your rear brake pipes and then I realised you haven't refitted the rear brake compensator.
Yes, well spotted. I am fitting an adjustable proportional valve close to the master cylinder to give me more control over the rear brakes.
smudger said
Looks smashing Jimi. Coming together nicely now mate.
Cheers mate
Yomp said
Also, I saw the heat shield missing off the fuel tank……
I will be wrapping the exhaust.
Matt
Looking good fella :-)
I'm keen to learn more about the proportioning valve you are fitting and where it would fit in the engine bay as my compensator looks a bit rough/dodgy and I'm not totally convinced how well they work on the bases of a spring on the rear beam…could you pls tell me more?
I also like the idea of more control over brake bias
I see you had the old spring re-plated but guessing you are not fitting it now?!
Would fitting something like this suffice?
http://www.ebay.co.uk/itm/BRAKE-BIAS-PROPORTIONING-VALVE-FIESTA-ESCORT-RS-TURBO-106-205-GOLF-GTI-CLIO-PE-/151162194405?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AGolf&hash=item2331f809e5#ht_2527wt_932
many thanks
Martin
Mars red Tin top 83' gti in progress
pazwaa said
Very nice jimi, coming together nicely
Matt
Thanks!
Ice2812 said
Looking good
Drapoon said
Hi Jimi
many thanks
Martin
Hi Martin,
No I won't be using that spring I had plated now!
I will be using two proportional valves, I have two reasons for this.
1. I have heard that having different fluid displacements on the two outlets is not good for the m/c and can lead to premature failure. If using one valve, one of the m/c outlets would have to do one front wheel and the other outlet would be doing one front then a tee to the valve and both the rears.
2. I wanted to retain the safety of the diagonal braking system. By using one valve on one of the m/c outlets for both the rears, if a fault occurred,split hose etc. i would lose both the rear brakes and also a front.
The proportional valves I have purchased are very similar ones to your link, also from eBay but unbranded but with m10 outlets. I had previously bought 2 wilwood ones but they have 1/8 npt outlets, I tried to find adapters but had no success so sent them back and got a refund.
I plan on mounting the valves close to the m/c and will probably make some kind of a bracket. I hope to have them installed in the next couple of weeks and will update my thread
Matt
