Mk1 GTI Cabby.The Project So Far... NOW SOLD :( !
They work great too.
Just a nice touch to be able to drop all four windows from the front 8)
Haven't wired them into the full closure yet as I need to get the car finished for the AGM. (it'll give me something to do over the winter months anyhow)
All my crossovers are fitted for the stereo components, ready to be wired up when the door cards are fitted.
The roof has started stretching nicely at last. I don't need to jump up and down on it to close it anymore!
Just a shame I have to strip it all off again to tighten up the headlining as it's not as tight as I'd like.
Will try to get the carpets and underlay fitted this weekend…
Mk1 Gti Cabby project on the go! Detailed engine, roof off, leather interior, 16's, painted, now getting put back together!
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=103263&start=0&postdays=0&postorder=asc
Nightmare about the headlining but it'll bug the hell out of me if I leave it. Decided to remove the whole roof and start again next weekend.
Got the underlay in…
Then time for the carpets…
Next fitted my kneebar (what a job trying to get to the fixings up behind the dash!!) Got there in the end.
Made a switch blank for the electric windows.
Fitted a new cigarette lighter (won't be using it, but atleast the light on it works now!)
Next… roof off (again!) and get the door cards fitted…
Bummer about the hood…as I said braver man than me! Hope you get it how you want it. I took a leaf out of you book and dynamatted all my doors etc. I have tried to fitmy door cards and rear cards and out with the new ones not fitting due to hole centres being out. I found I had to cut back the dynamat away from the holes for the clips as the increase in thickness made it such that it is not possible to push the clips in far enough. Just something for you to consider as it cost me afew hours of swearing and chin rubbing
Thanks for the heads up…
Another job to add to the list!
Yours is looking great by the way. Shame about the cards not fitting properly as you'd done a great job on the speaker install.
I own a convertible gti (DX) and I'm resurrecting,
excuse me for my English is not good
can you tell me the color code that was bringing the factory?
thanks
Your English is very good!
The paint colour is inca blue Metallic (lk5t)
Good luck with your project. Do you have a thread?
For anyone doing a replacement hood, make sure the roof is completely closed when fitting most of it (handles locked).
I had removed my handle keeps and just closed the hood but didn't lock the handles. This meant that everything was too tight once it went back together!
So….2nd time lucky!
Managed to get the roof stripped back to the headlining yesterday.
Tightened the headlining (with the roof fully closed) Re-attached the padding and fitted back (with the roof fully closed)
Just need to tape the front edge of the roof later today and re-fit the roof skin.
MISSION! I'll be able to do this in my sleep soon. Suprising how straight forward it is when you've done it twice.
Hope you get how you want it this time. I slotted my door cards yesterday and fitted the chrome strip to the handled, if I get it back from the body shop today I should get the interior finished. I think that will be it for a while as I am off to work for while. I will also not make the AGM as I have weekend tickets and finish line seats for the British GP which my wife bought me for my birthday so I will got get to see your finished project in the metal.
I will follow you posts while I am offshore great inspiration to me everything you do thank you
cheers tony
djrussf1 said
Thank you very much.
thanks for the information of color
well mine is blue
I love the first picture with the Lenso after polishing
I have no topic I have only the presentation of newbies
here http://www.vwgolfmk1.o…&postorder=asc&highlight=
I have almost finished and then to enjoy it for long time
see you soon
Career in fitting hoods. LOL. Not on your nelly! :wink:
Power steering…maybe in future…
Think I sorted the roof today though.
Roof now stretched into the correct position. Rear cable nice and tight. Roof is like a drum!
Thanks to Chortle once again. Told me to open up the rear lip around the corners to allow the cable to get tight in the centre at the rear. Worked a treat! Top guy!
Headlining could be tighter, but I'm hoping when I cut the rear window out it'll pull itself tight as it should relieve some tension on the rear roof frame.
Going to leave the rear window for a week or so to let the roof stretch properly.
Will be cracking on with the doorcards next…
Re-did the roof as I wasn't 100% with it.
Got it nice…at last and fitted the rear window. Quite straight forward really (compared to the rest of it!)
Result also…the relief of tension when I cut the window out allowed my headlining to tighten up. Yipee!
Got my interior in.
Wipers on.
Gearknob fitted.
Stereo system installed…more on that later…
Took her out for a spin as the weather was nice.
A couple of pics with my phone camera…
The Infinity amp I bought over a year ago (new) doesn't work! Typical. Out of guarantee also so can't send it back. Never even fired up once.
Tested with one of my brothers amps and it all worked A1. Sounded pretty good too but I may need to go for a 12" sub.
I'll see how mine sounds when I get my new amp (2nd time lucky!)
Got a few snags to sort.
Cold start issue (runs beautiful when warm)
Tune up
Tracking and camber
New amp
Capet needs re-fitting around the accelerator pedal as I can't plant it fully
Re-fit a couple of door card clips
Speedo not working
Treat the tonneau to a refurb to match my interior.
Not much. Should be good to go by the AGM.
Better pics to follow once I've got it all sorted a polished up nice.
1.8T CABBY
1.8T CABBY
My snagging list is getting longer but manageable by the AGM.
Very excited!
Looks like a week of sun this week so hoping to take it out again a couple of evenings.
Defo cabby weather today!
You must be over the moon with it.
Cant wait to see it at the AGM.
