mk1 20vt and mk1 PD
mk1 20vt and mk1 PD
jj weir
fitted the quick shift up to the gearbox, needed a bit of adjustment to clear the mk1 mount but now its on and I'm happy 8-)
me: www.facebook.com/mkoneman
work: www.facebook.com/obdworks
club: www.facebook.com/dubcluboxford
instagram: mkoneman
just heard from my mate at owen developments, ill have the hybrid turbo back middle of next week :wink:
instagram: mkoneman
drilled out the hubs and used the hydraulic press to slip the track rod flippers in
hub need a repaint but here's the results
my mate works on building classic race cars so he sorted me out with some heat wrap for the down pipe when its made
and last but no means least
:punk:
http://www.owendevelopments.co.uk/
instagram: mkoneman
What was involved in getting the shortshift to clear the mk1 mount?I fancy getting one myself.
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
turbo back on
instagram: mkoneman
Preece said
Great work mate! Where are you mounting the rear brake adjuster? what paint are you using to get the crackle finish? Keep it up mate
its mounted behind the centre arm rest in the centre console that runs between the seats, its black VHT paint mate
instagram: mkoneman
replace the old coil packs with a fresh set
old
new
next up i needed to sort out the OBD2 port as I'm running the standard management i want the use of the diagnostics port but to do this u need to be running the standard clocks as without this the vcds can understand the signals from the ecu
me and adam (bloke that deimmobilizes the ecu's, www.chiptunawarehouse.com) sorted this out on the crazyquiff demo 1.8t i wired up a few weeks back
so i dug the old clocks out from the mk4 i stripped cut the length off clock loom off
had a little look at the bentley wiring diagram found the wires i needed
that gives power to the clocks
so all i need now is a OBD2 plug and socket with a bit more wiring i will have a functional diagnostic system
instagram: mkoneman
Mk1GTi
Rallye Golf
Mk5 GTi
Mk7 GTD
Rallye Golf
Mk5 GTi
Mk7 GTD
instagram: mkoneman
Preece said
How do the mk4 clocks sit in the mk1 dash? Assuming you're using them.
no im not mate, they are used for diagnostic purpose only
instagram: mkoneman
may i ask how much they charge for the ko3's ko4 hybrid? i fancy one for my rado :wink:
but if u want a new one here is a rough price from jbs (there turbos are supplied by owen's) as owens hasn't got a price on there site
http://www.jbsautodesigns.co.uk/listing/67/jbs-04-k03-hybrid
8)
instagram: mkoneman
i have question to you,
im also using OEM ecu which is came with my engine and using mk1 clocks. But i can't connect the Rev counter any way. Some of friends told me i need a signal converter or something like that.
What about yours? Do you have any experiences?
thanks..
Graham
(Boraboy on most other forums)
Cabrio GTI Now in Lhasa Green with running 1.8T AJQ on OEM management.
Coming to bits again for more mods after reading to much on here…
Oh yeah, and a Golf V GT TDi
