mk1 20vt and mk1 PD
mk1 20vt and mk1 PD
have mocked up the mounts for the intercooler
should sit something like this
me: www.facebook.com/mkoneman
work: www.facebook.com/obdworks
club: www.facebook.com/dubcluboxford
instagram: mkoneman
im almost done with the pedal box at last, now got the fluid bottles mounted and the throttle and clutch/brake switches wired up
and just finished the clean up, repaint and regrease of the shifter tower, ready to install now
instagram: mkoneman
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
shame you can't keep the parts at quiff in the same order .
eg.THE LOOMS….. MERRY XMAS…….EVILBONA……
evilbona said
very tidy work !
tom im not happy abour quiff day change….
done a bit more today now xmas is out the way
finally got round to skimming the bay and getting a bit of primer on
just needs a dose of high build now then i can crack on with the colour
also go the car up on axle stands and removed all the front suspension
instagram: mkoneman
500x 1000 sheet
a few bend grinds and cuts later i was left with this
that fits something like this
nowhere near finished but u get the idea 8)
instagram: mkoneman
Love the re'engineering of parts, if there is a better way 8)
Any more progress?
I remember this years back on ed38, probaly 5-6 years back now!
Pete.
ditched the whole heat shield idea now as i had a look on the mk1 20vt at crazyquiffs and there is no massive need for it and it will hide my nice smooth bulkhead
ive mounted the remote servo
will be hidden by the centre console when its all back together
next i sized up all the hidden brake lines ready for flaring tomorrow fronts will pop out here
got my decoded and remapped ecu back today so ill get that mounted up tomorrow too 8)
instagram: mkoneman
Where you get that heat sheild from?
Mk1 Golf Gti Abf conversion Project
Mk2 Golf Gti 16v
Mini Cooper S R53 (Daily)
instagram: mkoneman
Mk2 Golf Gti 16v
just need to run the vacuum line once the engine is in 8)
painted up the ecu bracket and wile i was waiting for it to dry i took things a step too far and gave the ecu a polish 8O
a side by side shot with my mates decoded ecu for the R32 I'm putting in his corrado
i need to get some paint on the bay next so i can get the engine mounted
instagram: mkoneman
mkoneman said
haha yeah cheers dude its been a long time in the making
Only the bests ones are :wink:
Lol! - Polished ecu
Liking the remote servo, and location, plus all the hidden brake lines, very trick 8)
Whats the plan for the inside?
Pete.
How have you setup the brakes? you have 2 master cylinders an 1 servo, are you running the rears straight of the MC?
I have a remote servo and considered using it but didn't want to run all 4 corners of it and had thought to run the rears with out but wasn't sure if you could do it.
Graham
(Boraboy on most other forums)
Cabrio GTI Now in Lhasa Green with running 1.8T AJQ on OEM management.
Coming to bits again for more mods after reading to much on here…
Oh yeah, and a Golf V GT TDi
2 bias cylinders on the brake pedal
1 goes straight to the mk4 1.8t rear disk brakes via a adjustable bias leaver ( replaces the factory one that bolts to the axle) giving me 100% > 0% pressure on the rear brakes
front ones comes from the 2nd cylinder to the remote servo that boosts the pressure via the vacuum servo then splits off to the 4 pot wilwood front brakes
the single servo only on the front brakes has been tried and tested on crazyquiff rich's ABF mk1 and the system works fine and full MOT complaint and brake roller tested 8)
make sense?
instagram: mkoneman
instagram: mkoneman
