mk1 16v conversion,mot'd and running in
as of 9am this morning 21/10/2008 the car is MOT'd
straight through with a couple minor advisories that were on order anyway
getting a full set of rear drums shoes and cylinders
drivers side steering rack gaitor is also about splitting
couple of other bits that have been bugging me are the bumpers so ive got a new set of blacks coming,itll sort out the droopy indicator and freshen it up a bit
also want to get underneath now the brakelines and fuel lines are all done and clean of some surface rust on bits and may also steal my jettas seam welded wishbones and rear axle to firm it up a bit more and clean it up a bit then waxoyl or underseal the whole floor
mk1 1.8 16v
<a href="http://s277.photobucket.com/albums/kk54/tamthebam16v/?action=view¤t=05092008653-1.jpg"><img src="http://i277.photobucket.com/albums/kk54/tamthebam16v/05092008653-1.jpg" border="0" alt="Photobucket"></a>
roll on the re-spray next year 8)
spray adhesive
on
just as well as the weathers kinda turned
Pete
A std GTI one or a custom jobby?
I'm just about to do the conversion in a 1.3 too, it's all being swapped from a running Mk1 GTI with a 16v in there, so I just need to swap everything over.
Just wondered if I should use the std GTI pump or use an aftermarket one!
Any help much appreciated
Callum
Old enough to know better...
calum youll get away with the gti pump although i used much of the old digifant set up from my old swap
ross-m i cut up some refuse bags and just trimmed under the door panels then spray glued them on,the passengers seal was shot but seemed to make sense to do them both
cheers for looking and commenting
cars dead at all revs and wont pull over 5000
diagnosis-fuelling
swapped out the metering head and fuel pump and just got a lift pump to source and fit now but been on a bit of a wheel frenzy
too the 14" P's to the polisher and also my bbs rs's,the 14's are in the for sale section now but the 15's are currently getting some treatment
x
x
x
x
still got a fair bit to go though
Hope you sort your runnng issues.
pull away from the pump and ive got loadsa steam,popped a core puug from the rear of the engine
golf_coupe said
got more to worry about now,got up this morning and i had a slow puncture,drove up to the local garage to blow it up and its the valve thats knackered.
Gay!
Lucky it happened just as you were pulling away, a mate of mine had this happen on his kr, when he was ranting it 8O
Hope you get it sorted soon.
Pete
hopefully
:wink: which by the way look the shizzle
<a href="VW Golf Mk1 Owners Club"> <img
http://i35.photobucket.com/albums/d189/vr6lad/forumsig_h.jpg
