MarsRed Cab 16v Conversion * NOW STARTED*
Its always difficult to help with a non-standard setup, purely because anything and everything can go wrong but reading your last post I thought I would at least try!
I would suggest you take a step back and lets look at the basics because "having a twist of the dizzy" is not likely to solve your problem with any degree of success, and if your timing belt is out by much it will all be for nothing!
Check the timing belt is correctly installed, at TDC No1 all the marks should be aligned, the rotor should be pointing to no1 cylinder (not sure what ignition system your running) and the firing order of the ht leads is set to 1-3-4-2 and are in the correct rotation.
I will be about all day online so if i can help just post or pm (i am a trained mechy
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
Need to know.
Does the crank sensor read a set point on the flywheel like a cutout or magnet?
Reason I say this is bcos I've only just realised that when I was checking my timing. I put the car in gear and gave it a push to get the crank to roll. No drive!
I initially just thought ill sort it after I've managed the starting issue.
Since then I've thought it could be a possibility that the flywheel I got from the mk2 golf may be incorrect it it was ever changed.
So what specific points identify the correct flywheel (mk2 gti 16v) if the crank sensor does read the flywheel as so to speak. As this may be the reason there is no drive or not starting……
Cheers rubjonny.
mk1 golf - resto
mk3 polo breadie - daily banger
boyle_sbd said
do you want me to come round an hava look dennis?
Cheers dude. Let me check this tps first then im fresh out of ideas. If it isn't that ill give you a shout. Cheers Boyle
mk1 golf - resto
Got it started in the end.
Found a few things which were not entirely helping my cause
1. Fuel pressure is taking too long to build up. Whether this is due to wiring causing resistance or a fuel pump which is on its way out is yet to be established.
2. Spark is weak. Not sure why this is but I will check the mk2 coil, the dizzy and run some resistance tests on the leads as well.
3. Now this is the main issue. The fuel was no longer flammable. Must have been when I changed the fuel sender and didn't leave it sealed. All the vapor must have escaped and screwed the fuel.
So now it starts buts doesn't stay running for than 3 or 4 seconds. Probably idle stabilization valve so I will investigate if it will run will throttle and if it will idle once warmed up.
Ill be spending all Saturday doing this so ill update in the evening and let you all know how its going. And ill upload a hell load of pics as well.
Cheers to everyone for help so far..
checked out the car today
car starts but wont stay running. it just cranks up and then cuts after 3 seconds approx
spark is sufficient but could be improved
i suspect the fuel pressure, possibly the fuel pump is toast or relay is not putting out correct power.
so
Need to change fuel pump relay in the morning just to rule that out as I have loads of relays
Also
Is there a way to check if the pump is at fault or not. Or can I only go by fuel pressure???
While Im on the fuel pump subject. Can anyone recommend a good aftermarket fuel pump which can put out a specific pressure or is that asking too much.
What should the resistance be in the leads???
not sure on the lead resistance, if i was you i would just buy new plugs, leads, cap and arm from AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]. worst case if they dont help you have a good set of spares 'in stock' which is never a bad thing
check for 12v at the coil with the ignition on, and can you let us know the part number from the ecu? if its an immobilised unit that could be why it is cutting out after its started for a few seconds
I'll swap the relay and check pump and coil voltage say morning and give you a shout. I know for a fact the fuel pressure is not at the required standard.
2. Does the Immob need to be wired on as I only put it on as I thought it was needed.
I'll check the clicking of the box
