GTI Project #2
Secretary
GTI Project #2
1stgolf said
hi just wondering what your using to grind back the welds an angle grinder? if so what disc are you using?
thanks
mark
Hi Mark,
Yes Im using an angle grinder which I have fitted with a grinding disc, which is thicker than a cutting disc.
I bought some from screwfix. I tried cheaper discs before that, but they were crap. they hardly grind anything, just waste your time. Better paying for decent discs, gets the job done quicker. I cant remember off the top of my head what make i bought though, I think i went for Makita discs.
:wink:
Secretary
Secretary
Sorry!!!
woZa said
I think you can use a flap wheel to the same effect too…
Flap discs are excellent for cleaning up welds, i work for an engineering company and they all use them. Rough sanding discs with a plastic backing pad are also good :wink:
I like to use anti spatter spray aswell to give a cleaner weld
1989 VW GOLF GTI CABRIO
1997 VW POLO 1.0L
2003 VW PASSAT TDI 130 SPORT
1997 VW POLO 1.0L
Secretary
1997 VW POLO 1.0L
1997 VW POLO 1.0L
Frosts do them in sets of 3 at progressive grades so you can finish the welds nicely. As other have said they're great if you've got an awkward weld to get as as they won't mash up the surrounding metalwork.
See here: http://www.frost.co.uk/free_catalogue.asp
Look at page 3 under the welding section.
Top job on the rear panel, I'm looking forward to seeing the spare wheel well going in. :clap:
Mk1 Golf floor mats - for tin top and cabriolet - Zero7796 17298Five
1997 VW POLO 1.0L
1997 VW POLO 1.0L
Secretary
It is a bit rough and aint the best job that Ive done, but once it gets a fresh coat of paint (and the boot carpet is back in) it should be ok.
Im hoping to get the spare wheel well welded in tomorrow providing it aint wet or too windy. I will take some more pics and get them posted tomorrow. No slagging my seam sealer now.
Secretary
Found out that it aint a good idea to drop burning underseal into your eye. i welded one of the spotweld holes then looked under to put out the fire. i blew on the burning underseal and the next minute some of it fell onto my left eye. I now have a blister on my lower eye lid. ouch!!!!
pics will be posted tomorrow though.
Secretary
Firstly a couple of the inside of the rear panel
and the spare wheel well which is now welded in place
from underneath
and now that i have grinded down the welds
Secretary
and this one which I have welded up. Would I be able to get into this weld with a flapper wheel as I cant get it ground right down with the grinder without grinding the surrounding metal?
1983 1100 C
1983 1100 C
Secretary
markwon said
Looking good there, I've been using a Dremel type mini-tool with mini grinding disks to finish off tight spots like that. Very effective and helps give a smooth finish all round.
Thanks for that I will get the dremell out and see what I have available.
You will have saved a fortune doing all that work yourself.
At this rate you could do me a homer or 2 when you have finished im quoted 2-3k to get mine done later this yr.
All the best with the resto look forward to seeing some more pics. :wink:
