Golf Gti -1979
Golf Gti -1979
But it is possible to weld it back if someone wants that sometimes in the future!
But the car will probably remain this way because I have no plans of selling it!
Thanks anyway!
And Im sitting here and wondering on what kind of brake pads I should use!?
I was thinking a bit on the EBC green stuff,.. anyone tested these? Good or bad?
Or does anyone have any other suggestions? :dontknow: :roll:
Golf 1,6 GTI 1979
1.8T CABBY
1.8T CABBY
richyhill said
wow great thread mate, look forward to seeing this one done !
Thanks! hopefully it will turn out quite okay anyway I hope!
And I also have a little question that someone may be able to help me with!?
I'm thinking of making homemade fuel hoses from the pump to accumulator and from the accumulator to supply line..
And I plan to use 8mm nylon air line to that purpose, but what I need help with is the end fittings!?
I've looked around on eBay.co.uk a lot now and don`t know what kind of fittings i can use?!? Some AN fittings maybe?
The 2 I have the biggest problems to find is the 2 that sits on the accumulator..
So if anyone can link to "push-on" fitting that might work for my purpose it would be really great!
Golf 1,6 GTI 1979
Have a look here.
http://www.pirtek.co.uk/pirtek-products/catalogue/Catalogue-content/automotive-hose-and-couplings.aspx
I made my own fuel lines with connectors etc. Im sure you can order online. If you look through my thread you will see the hose and connectors. (if you can get through without falling asleep).
main pump banjo - M12x1.5
fuel filter input - M14x1.5
fuel filter output - M12x1.5
metering head wur line - M12x1.5
metering head main in/out - M12x1.5
see if any of the above lines fit your accumulator outputs then you'll know! they'll be metric fittings though either way
edit: but check out crazyquiffs wepsite to the left first. he does the 2 lines to the accumulator/fuel pump on their own if you want em
blancomcr said
Awesome job. Love the house. Im very envious.
Have a look here.
Thank you very much!
And thanks so much for the link! But I think I will ordered finished ones anyway, it was not so super expensive at crazyquiffs I thought it would be
But thanks for the tip, nice building you have there bye the way!
Massbad69 said
Loving it :mrgreen: :mrgreen: :mrgreen:
Thank you! I appreciate that!
rubjonny said
these are the ones I know
Thanks for those details!
Very good to know!
But as you write, I will order from crazyquiffs instead as that feels like it is easiest
Golf 1,6 GTI 1979
I have, bought a Golf GL from 1982 that I've picked some parts from to the GTI..
And I've also fixed a bit with the brakes!
In the rear, I began whit to put on new wheel bearings, brake shoes, hand brake cables and so on..
And in front, I got some ventilated and drilled 256mm discs.
Then I bolted up the carrier whit shoulder bolts, but it required a washer to centre the carrier properly.
And I had to buy a new repair kit to the calibra brake calipers because I got a kit for 54mm brake pistons… when I needed one for 52mm brake pistons..
So.. Now is the brake calipers in a little better condition than they was before anyway!
And here they are mounted. Right now i have only original calibra brake pads that are painted red.
But I havent mounted the steering joints and the calibra brake hoses yet.
And I also stuck on the radiator. The old radiator was broken, so I switched it out against an better used one..
Overview
And I also bought some parts for the exhaust system
Golf 1,6 GTI 1979
Mounted the litle bushings!
And I also extended this part so it should fit the five-speed gearbox
Golf 1,6 GTI 1979
Got some things done again..
Some oil..
And im going to use a oil cooler from a saab 9000 turbo on it.
And cleand some old engine hoeses and put on new clamps.
And puted back a few more stuff in the enginebay..
And welded a 3" "powerrorh"
And I have also welded a bit on the exhaustsystem
And a litle bit of color on it to keep the rust away.. a wile anyway..
And some pics on the alloys..
Regards Tommy
Golf 1,6 GTI 1979
good
Got i bit more done to!
I have painted my "powerrorh".. its look ok.. in a distance anyways!
And then i started to work whit the fuel suply..
The old fuelpressureregulator was in mint condition….
I found another one that newer been mounted on a car before
And some paint on it.
Some more parts
Dident found any foamholder to the pump so i did like this.. using a rubberblanket around it.
And some new 8mm copper fuel lines.. and mount the tank.
And i will also use this
Then i started whit the roof
Got some interior in to..
And i have also made a holder for the oil cooler
Wisch gona be located right beside the cooler.
regards
Tommy
Golf 1,6 GTI 1979
Golf 1,6 GTI 1979
The wheels are: Drag Wheels DR-20 15x7" Gold whit a 2.75" lip and a ET: 10.
And i also think its time for a litle update to!
To begin with, I have fixed the hoses to the saab 9000 turbo oil cooler.
So the oil cooler is in its place now.
And some "good to have things" before a eventual startup..
Then i would test to start it.. but it did not work.. hmm.. no fuel!
So i started to changed the pump relay.. that makes the pump worked anyway!
but still no fuel would come from the injectors so I changed the whole k-jet, and that did the job!!
BUT…the luck wasent for a long time.. The engine started.. thats good.. But either was the cylinder head a little warped!?,
or else it might was a wrong cylinder head gasket i goted that wasnt for a GTI!? either way, it spurted oil and water from the bakside
of the engine against the torpedo wall (exhaust and intake side). So that sucks! A litle movie of the start:
Water and oil from the engine
Sooo.. I feeeeel a liiiiiiiittle tired! :/
But.. I took out the engine and the gearbox again.. (yes.. I have also put on a headligt and a grill on for the upcoming inspection)
And now I had two choices, number 1: Disassemble and repair the tuned engine…
or number 2: Insert an original engine that already works..
And since I'm pretty tired of screwing with the tuned engine, I'll will go for option number 2.
Sad but true .. but rather that instead of that the car will standing this season!
Other engine options will be a matter for the winter 2012/2013 instead.
So..I bought a 1.8 JJ engine
So.. this engine is original but the least I could do for it to live for a while longer and look a little nicer is to freshit up a bit.. and also serve it with a new timing belt kit,
water pump, spark plugs, oil filters, oil, spark plug wires, distributor, rotor, glycol, air filter, thermostat and so on
so that it hopefully would roll on for a while to!
Some of the parts (everything is not in the picture):
And some of the items to be aded on from the "old" engine:
And after rain comes the sun … a refreshed 1,8 engine in this case..
And in the car again! But not teststarted yet because a cable to the disturber is broke.
And i have also bought a "new toy" a 1996 Calibra Turbo
Regards
Tommy
Golf 1,6 GTI 1979
