chassis legs-progress-pics
Hello folks,just an update on slow progress and some pics for ya'll!
welded in nearside axle mount repair panel this last week,will start
on rear section this weekend. Its just good to get some welding done
after lots of prep work,it looks so much better now.
1989 caddy
1981 gti
1993 cabby
Nice work - axle mount looking good. Always feels reassuring when you start welding in new metal. Did you use a Hadrian repair panel in the end, did it come with the brake hose bracket?
1983 1100 C
ahhh I remeber this, replaced both sides on mine, plus the rear sections. Not the nicest job in the world but satisfying when it was solid again. just finished painting the underside yesterday and it does look good now.
I used Hardian panels, good enough for the job trimed off what was not needed and they fitted a treat…
yea i used hadrian panel and it came with brake hose bracket on,needed some manipulation to get it to a stress free fit. good value for money though.
1989 caddy
1981 gti
1993 cabby
:D Nice work rustmuncher
Wicked job mate, ive got to do that to mine in the nxt year, as i,ve just plated it 4 da time being, be asking you 4 tips i think! nice work mate, goodluck with the rest. :D
heres what ive been up to since my last post,its coming along slowly the weather has been pants lately and dark nights are bad for motivation.
1989 caddy
1981 gti
1993 cabby
Thats some very tidy work - very impressive!
 8)
Nice progess, sum wicked pics there, your in deep now! :wink:  :D
Look forward to seeing more progess soon!! :y:
For anyone that has fitted new axle mounting points, when you came to fitting the rear brake flexi pipes to the brackets (the ones already on new axle mounting points) with the axle back in place did you find that they were out of position?  Mine are quite far out but the mounting points are positioned correctly. They will have to be removed and repositioned thats how far out im talking!.
:lol: Quailty work rustmuncher and in what looks like cramped conditions ? Keep at it mate . Do you weld for a living ?
Don't want to hijack your post but……
Dan you are doing something wrong can you drop me some pics ? I will post them for you on here and WE can sort you out
Cheers…..
No chudd me dont weld for a livin! fix them funny french cars with a lion on the front! Used to have a VW restoration business back in 96-98 but give it up for an easier life,mostly aircooled v-dubs but i did a few golfs along the way.
 Its a bit cramped in there i know espacially for a sixfoot two'er! Its no fun if its too easy.
Dani ill check location before i seal it up,it looked good lined up with the original though,maybe your bracket was on wrong from the makers.
1989 caddy
1981 gti
1993 cabby
As you will know if you have replaced them there is no way they could be positioned more than a few mm fore or aft due to them sitting over the axle mounting bolts so i dont know why the bracket is so far out.  I will try and put some pictures up
just grappled the back axle into position to check the brake hose bracket location,i have the similar problem to daniboy. ive had to relocate the bracket 3cm forwards towards the front of the car as the flexhose was overbent when in position and would not have functioned correctly and would have soon split. take heed people this bracket could be welded on anywhere but the right place on your repair panel.
1989 caddy
1981 gti
1993 cabby
I did take some pictures but have yet to get them off mates camera onto my pc.  How did you remove the bracket in the end?
The brackets welded on with three spot welds,i just drilled them out being careful not to drill right through the metal beneath them then used a bolster chisel to break it free.then re-positioned it using original flexhose and steel brakepipe to find the right position for it. weld it into place through the holes that you drilled through the spotwelds. job done! as if i didnt have enough to do already…
not took any pics yet but will do and get them up for you.
1989 caddy
1981 gti
1993 cabby
Mr rustie muncher, any more pics on progress? :D
Would luv to see how your gettin on with the chassis legs towards the rear panel, or any other progress.
Keep up the good work :y:
Ok cheers, i can just make out the three spots in one of your pictures.  What have you coated the underside of your car with to replace all that vw sealer? I have been told that stone chip will do the job?.
I've been smearing the same area of my car with TEX Seam Selaer then spraying that with stone chip paint.
1983 1100 C
I use 3m seam sealer,stonechip and shultz (steer well clear of tetrosyl products there at the bottom end of car products ,cheap and nasty). granville stuf aint too bad and good vfm. i got some pics of flexhose mount and rear chassis its taking shape a bit now,well at this corner anyway.
Here's where i moved the flexhose bracket to, only its own length out.
will soon be sealing it up on this side first with stonechip in the wheelarch area followed by shultz underneath,sprayed on for that smooth finish,then ill paint it with 2k in the spring when ive finished the other side.(well hopefully in spring anyway)
Christos is here again and im demanded in other things for a while.so wont be back in the garage until next year,how shat is that? still you cant have it your own way all the time. Chuffin christos eigh!
1989 caddy
1981 gti
1993 cabby
