Caddy MK 1 From Denmark Updat 03.02.14
(In Topic #150026)
Im from the little country Danmark, So my English meight not be the best (sorry)
Anyways. i have a small caddy projekt that i would like to share with you.
I have worked on the car for about 2 whinters..
It is my first car projekt, and probberly my last, i think it's a big projekt..
As you can see it's a normal 1.6 D, that i conwerd to 1.6TD, not the wildest engine, but here in Denmark nothing is legal..ewerything needs to be original
Last edit: by hypermagic
More pic's
And then the Paint go off, And i modified the Rear axle so it can go low8D
Then i get a Balma LT100 Air kompressor from a freind, becouse i was broked!
I tock it apart and found out the connecting rod was cracked! Lucky i could make 2 new my self.. and it run like a new one now
And i do also made my own sandblaster and it work just fine:p
Then i get some thing blasted and powder coated, looks great ithimk
My Porsche Güllideckel wheels is also almost finish, BIG job to get them fine, they were totaly ****edXXC
So i tried to put the subspention on and get it to the ground. just to see how the modified rear subspention work, and i figger after 2-3 years it would give me a boost to start again, if i put it on some wheels..
Well, It worked!!
So now i have sent the Porsche Wheels to a pro Painter,so they can be repainted..
And i order a lot of TIN (4 KG) for the bodywork..
so the plan is that, me and my brow will work for the whole weekend to get the TIN work finished.. so the painter soon can paint it
more
Tinning and Grinding like hell!!
One site Finish
Small update again matesNow in finish with both sites in the pickup bed, and the area around the Doors.. I only need the engine room, doors, front helmet, fenders, and perhaps i will by a new (volkswagen) rearend.. Then i got my porsche wheels again from the painter, But the paint job they had make, was realy NOT GOOD !! so, i got it for free.. then i tryed to watersand them and polish them, and they ended up pretty decent i thintButnow some pics for you guys
Now Wheels are totaly done, with tyres and final finsh Enjoy:p
Quite a fabricator aswell, the tig welding on the exhaust is neat as hell
Brad. said
Impressive to say the least!
Thank you mate Always good with a great komment..
Well i do Weldig for a living, so i suppose they are okay Thanks
Do You know a good pic uploade site?? The site i one use to use dont work any more! so i need a new one
MK1 Golf 1 GTI Pirelli
Photobucket? Or Flickr
W65_Pirelli said
Hold da op hvor er det lækkert arbejde
Heh, så lige en dansker… Takker du
arh okay Well, year it do help alot Thanks, I'l try thatBrad. said
Me too it helps a lot lol.
.hypermagic said
I had bought a new front, and i make i so i can bolt it on, in instead of weld..
the quality is amazing, and make my build look rubbish
Kunne godt lige bruge din expertise et par timer
