A589 VGB (The Blue Beast)
Cheers.
I have picked some Recaro's up for £50. Bargain I think. I just need to sort some subframes out now.
First up was removing the tar matt from inside the car.
When I got the passenger side Matt off I found where the floorpan meets the inner sill had rusted through .
Then I started on the passenger side wing.
More coming tomorrow.
daztheoneclaw said
Looks like your local to me fella. I saw your tank at Impreziv the other week. Give me a shout if you need a hand with anything mate. :wink:
im in durham, might enlist ya help
and you chidz!
i'm doin a 1.8 16v into 1.1
Best advice I can give is just get stuck in and learn as you do it. I am learning myself but these conversions are common and there is lots of info out there about it. Plus the forum members are always hapy to help, it's well worth joining up.
I thought since I was on with removing the underseal yesterday, I may as well carry on today. So I got cracking with the drivers wing then rubbed it down with white spirits to remove the last bits of it.
Then I decided while the suspension was off I would tidy up the turret. I had welded up the holes previously but couldn't get the grinder in while the top mount was fitted, so first I smothed the 3 welds down.
Next i welded some bolts in upside down for the top mount, witch makes the top of the turret look alot smother.
I got the keys to the new unit, so we'll have a lot more room to work soon.
Had a couple of hours today so I got the 100mm drive shafts on.
Then I started cutting and fitting the fuel lines on the carbs.
I wanted the fuel line hidden so I added some thin metal under the rear engine mount to hold it.
Then fitted the Facet pump.
OZ Turbo's coming soon
I got the OZ Turbo's for £200
I am not 100% sure where to get them from but I think it's Rally Design. Hope this helps.
As you can see there is no lips but this doesn't matter as I want to put different size lips on anyway. Also the flat centre's don't sit flush so will have to get some new ones made up. Dispite this I am still chuffed to bit's with them as they only cost me £200. Let me know what you think.
But I honestly think this;
Chidz said
is a bad idea. This rear gearbox mount hangs very low so unless your running it at standard ride height you'll risk pinching the line and cutting it in two eventually :dontknow: How about welding little holding tabs to the side of that mount rather than the inside the hollow. That way the line runs round the side rather than underneath?
I ran it underneath rather than on the side of the mount due to wanting it to be hidden. I have wondered about wether it will get caught or not and I don't think it will unless I crash. The sump sits considerably lower than the mount, and the gear box is a fair bit lower so a rock in the road should be cleared by these. A speedbump situation would mean the tyres would have to be higher than the mount for it to catch.
Has anyone run it this way before if so did you have any poblems?
Any ideas much appreciated.
A speed bump would still be a problem though because that mount is behind the front wheels. So when the front wheels drop off the bump the body will be very close :? But I guess its only a problem if you're pretty low, maybe you arent planning that in which case its fine! 8)
Anyway, I'm not trying to take anything away from you, your work is really great! Car looks amazing, look forward to seeing it on the OZs 8)
