A few questions to help me get started
Greg said
So the rear intermit will work with a fwd push on the right stick, and stop with another fwd push?.
Exactly, every 6 secs until you push it again (or turn off the engine).
Not too close to Berks, I know, but there is a good Audi breakers in Hockliffe, Beds (on the A5). 90% Audi's but the VW's he gets in are usually highish specs (GLS, GTI on older ones & V5, V6 4-motion, etc for newer models)
'83 Mars Red 1.1 C
Mk1 VW Golf 'c' restoration job....
Type17 said
Greg said
Also, if you fit a rear wiper relay from a Mk2 Golf/Polo (marked "72" on top), it will give you a six-second intermittent rear wiper (ideal for driving over 40MPH in the wet).
Now that is a useful tip. Wish I'd known that when I had a CL model golf. I did some clever wiring on mine with a switch so I could switch the rear wiper on when I wanted because as I remember it, it only worked when you pushed the stick to operate the rear washer, damned annoying!
1983 White cabriolet GTi
It parks a bit high in between wipes though for some reason - perhaps i have the older relay i forgot to check. But it cost nothing and i'm pretty pleased. Thanks especially to superworm for looking up the numbers.
'83 Mars Red 1.1 C
Also fitted a nice GTi centre console, sans gauges though.
'83 Mars Red 1.1 C
The gearing of the speedo is dependent on the drive gear at the gearbox end of the speedo cable - different colours define the different numbers of teeth for different final drives in different gearboxes, so changing the speedo head will be fine - it's changing the tyres' circumference, or the gearbox, or the speedo cable drive that will affect the readings.
The wheel height makes sense now you mention it. Although i used to be told i was doing 92mph at full knacker, but since the GTi clocks are in, i only reach 86mph
'83 Mars Red 1.1 C
Are the front wipers not parking correctly in between intermittent wipes AND when you turn them off, OR do they park fine when turned off, but are too high between intermittent wipes?
If they are wrong in both cases, you need to reposition the crank-arm on the motor. Loosen the 10mm nut when the wipers are parked (too high), and wiggle the crank-arm to break it's grip on the motor's spindle, then manually move the two wiper arms to the correct park position, and re-tighten the crank-arm nut. Test any changes like this, for the first time, with the wiper arms RAISED, just in case you've got it wrong!
If they park fine when turned off, but too high during intermittent operation, the wiper arm spindles at the bottoms of the wiper arms, are corroded and siezed. You'll need to diassemble them to clean and re-grease them. WD-40 won't do any good here - they get quite rusty, and the only solution is a good clean-out…
http://portal.campaignregister.co.uk/modules.php?name=Forums&file=viewtopic&t=1237&highlight=
On normal wipe they park 4 inches high, and on intermittent wipe they park about 10 inches high. But in both cases the wiper arm moves up to the correct position, then down to the correct position, then up a bit to park if that makes sense. See pic.
Hariy, thanks for the link. Nice work Riley!
'83 Mars Red 1.1 C
The park is set wrong, even on continuous wipe, so follow my bit above about loosening the crank-arm and setting the park for the wiper arms manually, and then re-tightening the nut on the motor's spindle. This should sort out the "4 inches too high" issue on normal (continuous) wipe.
Then, if the intermittent wipe's park position is still wrong (perhaps 10 minus 4 equals 6inches), you'll need to follow Riley's excellent "how-to", to clean out the spindles (might not need to do the motor too, I'd do the wiper-arm spindles first, and then see if I still needed to do the motor, as it's a good bit more tricky).
The reason the wipers stop in funny paces when the spindles are stiff is that, on a single intermittent sweep, the intermittent relay gives power to get the (well-lubed) wipers up to about 14 inches, and then cuts off, this design assuming that the park circuit in the wiper motor will finish the job. The problem is that the park circuit only starts at about 12 inches, and if your spindles are stiff/motor is slow (tired windings), the wipers haven't got high enough to "catch" the park circuit and get left at about 10 inches up the screen, until the next wipe cycle about 6 secs later.
'83 Mars Red 1.1 C
Also, remember that, on a Mk1 you CAN'T raise the bonnet with the wiper arms raised!
'83 Mars Red 1.1 C
Must be to do with atmospherics and a good waxing, but last night i managed 92mph again . Felt solid too
'83 Mars Red 1.1 C
'83 Mars Red 1.1 C
What was 100mph like in a 1.1? 8O
at 100mph it felt surprisingly solid.
'83 Mars Red 1.1 C
