1980 Mars Red GTI BRMotorsport 142
1980 GTI
I did like your car on the 14 inch bbs but I do prefer fifteens .Look forward to see how low you have it as i plan on putting on the gti spoiler onto mine and also running fifteens.
I guess it will be more practical on 15's ?
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
If they don't sell, I'm not fussed, but thought I'd give someone else the chance to own and enjoy them.
I think I'll still buy some other wheels so that I can drive it harder again.
Before I do that though, I may just swap out the centres on the rear for 10mm more tuck under the arches, and also get a bit more camber on the front.
Here she is in her new home…
1983 Black GTI
1983 Black GTI
Kedge said
Just flicked through this thread start to finish…….AWESOME!!!!
Thanks. Glad you appreciate it.
The KW's have turned up. They seem good…
It's time to get cracking on with this project now. I've got loads to do on houses, other cars and bikes that keep distracting me.
After some thoughts about swapping the wheels or getting them to fit the car better, I've got some actions to follow through with. I realise that I have the option of using the spare centres to build up another pair of wheels, but with the benefit of them having a BH 0mm, which means they will alter the mounting face of the wheel centre by bringing the whole wheel 10mm further inside the wheel arch. This will stop the rims from protruding so far out. This can only be done where you are running drums on the rear, as they will allow a flush fit against them. Rear disc calipers might interfere with them being so close. I will also pull the arch return lip out a little bit more so that the edge is pointing away from the tyre, rather than pointing to it. This way, any minor touching won't result in the tyre being dug into so much. But, as the tyre will be pulled in 10mm, there might not be an issue with this so much anymore.
As you can see from the pictures, the centres are just in etch primer to help protect them. I will send them off for stripping and painting this week.
The bolt holes on the 2 spare centres are straight forward drill holes without any lip or chamfer. I will have to get some big chamfered washer manufactured to accommodate the wheel bolts. Plus, it will help match the existing adapters for the original 4 wheels.
For the sceptics…
The flip side…
BH 0mm…
Just looking online at German websites to see where I can get some 14 inch inner and outer rims from, as I would rather build a fresh set of wheels.
I'll update soon.
1983 Black GTI
1983 Black GTI
Slightly off topic looking back through your thread how wide was the lower trim decal that runs along the bottom of the tailgate and I know you repositioned it .Could you give me a measurement from the bottom of the tailgate.
I had the trim decal with my rear screen decal but it looks too wide :roll:
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
Just under 9mm
1983 Black GTI
1983 Black GTI
I take my hat of to you for such an amazing vehicle :notworthy:
MK1 Golf - 1.3l Driver
MK1 Golf - 1.8 GTI (Build Thread - Here)
benandemu said
Just under 9mm
Thanks Ben ,and how wide is the trim decal ?
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
mark83 said
benandemu said
Just under 9mm
Sorry, I didn't read your question right. The decal is 9mm, and I'll get back to you with the distance from the bottom of the tailgate.
EDIT: The stripe sits just over 2mm from the bottom edge of the tailgate.
1983 Black GTI
1983 Black GTI
1983 Black GTI
1983 Black GTI
Thanks Ben, it's a small detail but I wanted it right.
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
They are made from compacted fabric which tend to lose their stiffness over the years and consequently flop down and lose their shape.
After a long period of time, a good friend and myself had a mint set between us that we had gathered from cars we'd owned. As we wanted a set each, and were concerned that the original ones would no doubt perish along with others of the same age, we set about making our own. The patterns are actually different between the years on series 1's too. These are moulds taken from original GTI ones.
Hope you like…
Drivers…
Passengers…
Also picked up a Volksport front lower strut brace from JonP on here (thanks Jon). From experience, these make the most significant change to the front of a mk1 for improved handling on the road. It needs a stripdown and powdercoat before fitting though.
1983 Black GTI
1983 Black GTI
We made them in thin'ish semi flexible fibreglass and then covered in self adhesive acoustic cloth which is virtually identical in finish. The key to good ones is to have a good original one to mould from.
We have 2 moulds and could potentially make some more, but I haven't considered cost or time really. We also have some good earlier moulds too, including swallow tails.
Only thing I may have to alter is using a little black button head screw and captive washer above the pedal assembly as the original push fit grommit might not be up to it. A minor detail that I feel is worth the compromise.
Just fitted these up and they're fantastic. No photos though as it was too dark in the garage and I didn't pull the car out.
EDIT: picture added…
Last edit: by benandemu
1983 Black GTI
1983 Black GTI
I'm building a set of 8's and 8.5's at the moment and am a bit worried about how they will fit!
1983 Black GTI
1983 Black GTI
There's another 6 week delay on the wheels as the wrong size outer rim was produced, and I have to wait for the next batch.
1983 Black GTI
1983 Black GTI
