**OPEN AIR 1.5 GL 5DR 1982 FULL RESTO**
i will get some more pics up soonish engine stripped to head and block now so hopefully tomorrow all parts will go through parts cleaner little blasting and be ready for some paint :) apparently you can run abf with just normal dizzy on and carbs with no advance timing or anything and it will run all ok so wait and see lol
ZX9R CARBS
20170301_222738.jpg 20170301_222749.jpg 20170301_222803.jpg 20170301_222831.jpg 20170304_120539.jpg 20170304_120545.jpg 20170304_140506.jpg 20170304_140514.jpg 20170304_141519.jpg 20170304_171834.jpg
6 years in storage and finally got it out to new garage to try and crack on with it.
Coming on nicely  :thumbs:
20170305_160715.jpg 20170305_165005.jpg 20170305_174833.jpg 20170305_174925.jpg
Abit more to grind back but that's it for this week
20170315_214300.jpg 20170315_210532.jpg 20170315_193238.jpg 20170312_175014.jpg 20170312_153437.jpg 20170312_122833.jpg 20170308_221804.jpg
59 views (3 Mb)
Engine bay is coming along nicely, looks great  :thumbs:
Matt
20170325_184904.jpg 20170330_224713.jpg 20170330_225046.jpg 20170330_225129.jpg
Some new wheels, abit early for wheels but saw them and bought them lol started on the inlet manifold last night and have nodiz management turning up today so want to try get engine up and running in few weeks check all ok before removing to do some more work on bay. Managed to get an 8v alternator and bracket so that's that sorted.
Oooooooh Fabrication!
Like it  :thumbs:
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
Abit of milling and got the rough shape so can tweak to fit. And started the water flange as original plastic one will be in the way with carbs.
Inlet back from a friend that welded up, looks good for first attempt
lewisf89 said
tonight have bought a set of ZX9R bike carbs for it and just trying to still get my head around this advance timing thing???? vacum dizzys, running ecu? ideal i would like carbs bolted on with no vacum pipes as little cables and pipes as poss! i have heard that you need to have advance timing some how to get full rpm range running.
with bike carbs ways to get advance timing are either.
1.run ecu
2.vacume dizzy
3.weighted dizzy??
if vacum dizzy used whats it off how to fit??
really do want to avoid electrics and ecu's where possible.
" i have heard that you need to have advance timing some how to get full rpm range running."   you need to advance timing but this doe not have to be done via vacuum it can be done via engine rpms.
You need to know what vacuum does to make a choice.  you will need a vacuum source to feed distributor/ecu with a signal and your servo to even work
When you have one carb or a gti like plenum all 4 cylinders are drawing at one chamber and a high vacuum signal can be found.
Also know that highest vacuum is a low load part throttle/off throttle , at wide open throttle (acceleration) vacuum is 0.
So with bike carbs you, each inlet sepperated, so your only get 1/4 vacuum if you get signal from one carb inlet, you would have to tap all 4 inlets and and T them together (unless they are connected by a balance pipe.)
Long story short a vacuum signal shows the engine when it on light load/cruise, so you can run the fuel air ratio lean (which needs igniting earlier in the cycle) hence more advance.
basically I would just run a centrifugal only advance distributor,  idle advance about 10/12 degrees and total at 2800/3000 at 28/32 degrees.  once you go bike carbs your not think econemy cruise.
I would be more worried about getting adequate vacuum to run your servo.
OK thanks very much, current plan is no servo any way and make a pedal box to remove as much from bay as possible.
20170430_112016.jpg 20170430_130942.jpg 20170430_130947.jpg 20170430_160446.jpg 20170430_160507.jpg 20170430_160520.jpg 20170430_160533.jpg
Looking good, I hope your going to run an air box and filter. (ring wont last without)
pedal box will sort lack of servo and bad rhd brakes.
just need a distributor of the right spec now
these guys might have something to cover your distributor,  or you can use your OG distributor with the vac plug up, but will have to get someone to custom curve the mechanical advance via the spring and bob weights.
http://www.123ignition.nl/product.phtml?id=243
Last edit: by Keith Usher
