'79 diesel LHD
Good news this evening. After an overnight charge, I switched on the glowplugs, waited 20 seconds, twisted the key and she started, just like that.
No smoke, no new rattles, no noisy tappets, no leaks (after a couple of checks)
I took her for a quick run, and she's just like before, perfect!
Now she needs a good wash and she'll be back in daily use.
Thanks for help, as ever,
Robin
VW Golf 1500D 5-door 1978 - was daily (wet)
VW Golf 1800 cabriolet 1980 - daily (dry)
Bedford CF Trailblazer 1978 - camper
Bedford CF 350 Flatbed 1976 - fun/work
Mercedes W108 280s 1970 - dusty and forgotten
Mercedes S123 200T 1983 - to be renovated
Mercedes C124 1989 - Winter Beater
BMW E21 1976/82 - dusty but not forgotten
Twingo 2004 (not my fault, somebody gave it to me!)
jellybelly said
Glad you've gotten it sorted
The sweet sound of a diesel
You're absolutely right - it does sound sweet. I"ve been running around in my 1800 cabriolet recently, which sounds OK but is a bit rattly, and in a lovely Twingo 1.2, which sounds horrible (oem spec) and it was such a relief to hear my old diesel again. I'm really looking forward to putting it back into use.
Plans are to tidy up a few things under the bonnet, then break out the mig again. The top edges of the front panel are holed, and the sills are on their way out, so I'll be looking for advice on the best way to do them soon.
I think I'll just enjoy the old girl for a few weeks first.
Robin
Your thread inspires me.
Ben Cavers said
My dog gets excited when I come home in the 1.6d!
Hi,
I don't have a dog but if I did he would love the car.
Took it out today for the first time in a month or so (I've been away with the 1.8 cab on the Atlantic coast)
Started first time, no smoke, only rattles. So nice to drive…
Things to do in the next few weeks:
1: spongy brakes
2: ropey sills
3: clean her (maybe)
News soon, I promise!
Robin
I found a asmall leak under the brake light switch which was making the brake pedal soft. I assume this is some sort of pressure sensor:
A new switch was 9 Euros with a new boot:
The switch took only seconds, but the boot needed carefully cutting and stretching on the wire outlets to get the spade terminals inside. Final result is much better though:
There's another switch further back which will need a new boot too:
Also in the parcel was a large scary piece of metal:
A full sill for the drivers (LHD) side. It was not so much more than a repro part (70 Euros vs 35), and seemed to make sense, though I'm not sure where to start really. I'll wait until I'm feeling a bit braver.
Robin
PS: Does anyone know where I can get a RHS sill for a 5-door? The company only has LHS
Strange!
I'll try it on the road tomorrow. Maybe it's just a sticky switch,
Robin
The lack of updates is simply due to the lack of work done on the car, but that is going to change pretty soon. It needs new tyres (done 50 thousand km and I bought them s/hand) so the wheels, brakes, ect, will be checked and painted at the same time. The front wings are detached at the front bottom corners, and one sill and one rear arch will need work.
Only recent job is a new speaker!
Robin
Sent from my Smartphone 📱
Golf Cabrio said
Hey Robin that speaker looks cool mate! 😀 😉👍🏼
And the sound is just so much better than the old AM radio with 1970s speaker on the dash.
Robin
I bought a 78 RHD 5 Door diesel with the intention of restoring her and she been sat for 2 years now… shame will be selling her soon
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
Chairman
'79 diesel LHD
allana13 said
Looks good man and lucky you are doing work to it
Sorry to hear you’re selling, I could be interested though! Sorry to highjack the thread!
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
decided to try to fix a cam-cover leak today - big mistake! I ended up making it worse, but hope it is solved now.
Basically the block was oily at the timing end, both front and rear:
I cleaned it up, got a new gasket, removed the old one (rubber, but with old style studs), fitted the new one (rubber again, but with new studs) and tightened it down. My VW parts supplier in France can supply cork gaskets and rubber gaskets, but didn't seem to think the studs were needed. I since found out they were longer and thicker… (Oh, and I painted the racker cover while I was at it)
Next day, after a short run, twice as much oil coating the whole of the front of the engine…
Had a look inside, everyting was OK, but, oh, there's no plastic cover on the early models…
A quick check on a spare engine provided rhe necessary cover, all clean and re-fitted now, but I really think I should have done better the first time. The torque setting in my manual is too low for my torque wrench. Is there anything I'm missing?
Robin
you cant over-tighten either the rubber or cork gaskets (well, unless you go mad and strip/snap nuts/studs ) the nuts tighten up to the shoulder on the cork gasket studs, and on the rubber one there are metal inserts round the stud holes to do the same job.
