Rattling from Front passenger wheel
(In Topic #197603)
no pun intended
Regards James
regards
Whip the front wheels off and you should see it from the top of the caliper. If it's there and fitted correctly then it *shouldnt* perish/go wrong, but if whoever did the brake pads last forgot to put it back in you'll get an annoying rattle unless you brake (brake pads can float around and hit the caliper and disc until a clamping force is applied when you brake)
