New linkages and bushes still problems
dont jack it up! this could lead to you over-fillign the oil, as you wont be able to drain all the old stuff out with it fitted on the car. just drain what you can, then refill as above.
when removing the speedo cable its key to not put any kind of force on it, once you have it loose. basically if you catch the gear on the lip of the hole you'll pull it off the shaft so once undone carefully release it and wiggle till it comes free. it might be stuck in the hole so only use force to free it, preferably gently lever the top plate up a bit rather than tugging hard. and try not to damage the seal, though you may just want to buy a new one anyway while there as they arnt expensive.
If you phone up and tell VW what car you have they should have no trouble getting you the right oil
Good website
020 Oil
2001 Zafira 1.8
2001 Zafira 1.8
1. Remove NSF wheel and level the front end using axle stand
2. Loosen filler hole then drain hole
3. Drain all old oil
4. Remove filler and let some oil in and see some run out through drain just to see it come through
5. Close drain and use the spout of the bottle through the filler hole till it triccles out then close filler hole
6. Start her up and select through gears or go for a drive but best not lol no tax or mot so let it stand on drive
Hope my step by step was good enough lol
if the front is in the air that'll give you a false reading as the engine will be tilted further back
I lie on my back and with my feet sticking out from the front of the car you can get your head under the arch and see in to the filling hole, just don't push the bottle in till it stops as it hits one of the gearbox cogs and the oil does not come out of the bottle very well.
Leave an old rag on the floor under the filler hole to catch any dripping oil.
17mm allen key or you can buy a little socket to do the job.
Looks like this, 1st one I found so shop around…
http://www.ebay.co.uk/itm/DRAPER-38323-17mm-HEX-DRAIN-PLUG-KEY-3-8-SQ-DRIVE-AUDI-BMW-ROVER-VW-GEARBOX-/151402630118?pt=LH_DefaultDomain_3&hash=item23404ccbe6
Is 75/90 oil, I did ring vw but there parts department was closed till Tuesday so just thought il look around and saw this MTL REDLINE that people say it's very good for the gear changes, would be nice to hear peoples views on this
