Is this bad?
Hi guys.
Recently I've had new spax coilovers fitted with new Febi top mounts. Had the tracking and wheel alignment done straight away. After 50 miles of it running straight the tracking was out again so took it back to the garage and they said it needed new wishbones and ball joints. I had planned to replace these anyway so I went ahead with it. Again after about 50 miles of it running fine the tracking has gone bad again. Looks like the plate on the top of the top mount is bent. Wasn't like this when they were fitted and don't remember hitting anything too hard. All the coilovers are set at the same height. . Could this be the reason or is it unrelated?Could it also be a problem in the steering rack?
wheels straight ahead? the tops will move in different directions if the steering is turned
Yea the wheels are facing forward. I'll try turning them on the spot and see what happens. Any idea of what else it might be? Cheers mate
ah ok if straight ahead id be looking at the top mounts then, what make were they?
have a look at the steering rack though make sure its not shifting about in the bushes i had that problem before with loose nuts. make sure its centred properly as i found my driver side wheel had been hitting the arch which may have helped loosen the nuts
They look like Febi top mounts by the writing on the top, could be one is faulty or something not fitted right, they should not look anything like that.
Has the Camber been set up, could be whats making the strut sit at a funny angle?
