Having trouble selecting gears
(In Topic #192474)
I sometimes have trouble selecting 1st gear. As I go to pull away I find out it’s in 3rd gear. Once I finally get it into 1st it fine.
Sometimes I have trouble getting from 1st to 2nd I just end up forcing it into 2nd. I have no problems getting into the other gear
This doesn’t happen every time it’s like the car knows when I need to get a quick getaway the car say no chance.
One of my mates said could be gear linkages but just thought I would ask on here before I do anything
Thank you
Thank you
Really common problem, quite a few posts if you use the Google Search on the left hand side.
Here is a comprehensive guide, should help you.
http://vwgolfmk1.org.uk/index.php?page=cedi&type=misc&id=42%2F2
its sounds deffiantly gear linkages i had the same problem .really easy to change put the car on axle stands the higher you get the car the easyer it is to do
I take it this will be the same if you have the 20vt engine?
I found lifting the clutch then pressing it back down helped?
