Gearbox or my Linkages. Not to sure
(In Topic #196049)
As i was going up through the gears it all seemed fine. As i came to a set of lights i went into neutral, then when i went to drive off i could not find 1st, and the gear stick had gone all loose and could not find any of the gears. After a fiddle around i got 3rd and managed to pull away and found 4th too. but the other 3 gears and reverse i could not. It has a scirocco 1.8 5 speed box inside.
im not sure whats gone wrong but I've still not had chance to look yet as really tied up with work
many thanks
You can see both arms from above the gearbox so you should be able to fix the problem without the need to jack the car up or any tools.
If both arms are attached you will need to look further into the the linkage set up, you can use the same guide on replacing the bushes found on this web site.
thanks for the great help as always
