G60 brakes upgrade to S2
(In Topic #204181)
Hi all just a quick one
I have a g60 280mm set up on my mk1 - I've just bought a set of S2 brakes to replace them
So my question is can I use my (epytech) adaptors or will I have to change them as they lost them differently on the retrofiction site
But from the info i found online say to use g60 adaptors
Don't want to spend £85 if I don't have to
The proper S2 epytec mounts take into account that the S2 brakes are designed for use with a 276mm disc and therefore moves the caliper out 2mm to use the 280mm disc..
But I'm pretty certain you can use your G60 adaptors and ignore the 2mm difference
I originally bought the Epytec G60 adapters from Just Caddy's to use with S2 brakes and found that the adapter fouled the caliper before I could get the second carrier bolt in. More metal has been removed from the S2 specific brackets to allow them to fit.
The guys at Just caddy's exchanged mine for the correct ones as they were still new.
Hope this helps.
Hope this helps.
