Difference between gearbox mount bushes
(In Topic #194903)
171199214D vs 171199214H
I am in the process of replacing my gearbox mount rubber bush. The part listed for my 1992 Cabby GTi is 171199214H (64.4mm). Locally in New Zealand I have only been able to find part # 171199214D; it is also 64.4mm. Will I be able to use this part? What is the difference between the two?
Thanks!
Thanks!
Quick search on the internet brings up this not sure if its much help, what's wrong with your mount and any part numbers on it?
Is this one for a diesel car but may fit?
http://www.veedubmachine.co.uk/gearbox-mount-for-volkswagen-mk1-golf-jetta-gti-gls-dtd-engines-p-2590.html
Or 4 speed gearbox on this one but vw heritage states it fits?
http://veedubmachine.co.uk/engine-mount-vw-golf-mk1-inc-cab-scirocco-jetta-caddy-p-1395.html
https://www.vwheritage.com/shop/171199214D/engine-gearbox-mount-mk1-golf-jetta-scirocco-64-4mm/?country=GB.HTM&lang=EN
171199214D appears to be for smaller petrol engines, ideally you want the H one for 1.8/diesel lumps
